I found a 12 bold rear end at a swap meet for my GMC today. Very similar to my 10 bolt, but it's a 12 bolt and has slightly better gears for the way I drive (3.40 vs. 3.73). When I took the cover off today I was presented with this:
My question is, what is the assembly on top of the regular gears, and what does it do? I'm sure it's quite common, but I have never seen it before. I'm talking about the parts mounted on rods going left to right in the picture. The bottom piece spins, and the top piece rocks back and forth. It is driven by an extra gear that goes around the planetary gear on the right.
Do I need it? It looks like some kind of sensor, but there are no wires going from it that I see. Everything else looks normal.
The problem I am having is that it has a big steel block behind it, and that seems to be preventing me from pushing the axles in to remove the C-clips. I need to remove the axles to see if they are tapered or not, as I'd like to get it narrowed slightly at some point. I removed the center shaft like you would normally do to push the axles in, but something is still preventing them from going in far enough to remove the C-clips.
If I need to remove the mystery assembly I need to know how to do it correctly. So far I'm not seeing it in any of the manuals I have.
