I too am curious as to how much it will sell for. Not to rain on anyone's parade, here is my take on the car, and how I would look at it if I were going to be buying it.
I know from experience, that an engine manifold leak can be a cracked manifold, and that in order to replace the exhaust manifold gaskets and or the exhaust manifold, you have to first remove the intake manifold, and then the heads, after you take loose the engine exhaust Y pipe. The Y pipe is what connects the exhaust manifold to the exhaust system. If any of the exhaust manifold bolts break once you have the heads off, then you will need to send the heads to the machine shop to have them removed. On my 1969, more than half of the exhaust manifold bolts broke, and the machine shop charges by the bolt to remove them. In my case, I replaced all the manifold bolts, and the head bolts, and it cost just shy of $200 for the parts. Machine shop services were about $250 - $300, and labor was $450, so I estimate the total as just under $1000 to do this job. If I needed to buy an exhaust manifold(s) it is anyone's guess as to how much they would cost. On eBay, one is available for $289 including shipping, and a manifold gasket set including bolts is $70.
The next item is the windshield, with a cost of approximately $1500 buying it directly from Pilkington Glass, plus the cost of installation of $300. If the glass breaks during installation, then it is on you, since you supplied the glass. If the glass company supplies the glass, which will cost more than the $1500, and it breaks during installation, it is their problem, because the glass belongs to them. Sometimes saving money on the part, can bite you big time, and other times, you win. Just depends on how comfortable you are with taking the risk.
The air conditioning "needing a charge" is an open item. Refrigerant just doesn't disappear, there is a reason that it left the system. It can be a broken hose fitting, or as simple as a failed "O" ring. I just completed the task of replacing all the "O" rings on my 1969, and between doing that work, and I have about 5 hours invested in attempting to make my cars system "leak proof". I know that all the fittings are tight and leak proof, but I don't know about the hoses. Only time will tell if there is a leak. I checked my system with an electronic leak detector, and couldn't find any leaks, but with these large systems, it is difficult to check the lines going to the rear air conditioner. I was quoted $125 per hour to service my cars air conditioner, plus the cost of the refrigerant. To get a non working system back in working order, would be a difficult thing to estimate, but I would feel comfortable with estimating it at $1000 without any electrical troubleshooting.
Wiring the Federal Q siren, would be the cost of the wire, solenoid, switching, etc., and if you have the experience, you could do it for under $300, with your labor being free. If you have to pay someone else to do this, then figure 3 or 4 hours at most. Most electrical shops charge between $75 - $100 per hour for labor.
The seller doesn't make any comments about the mechanical condition of the vehicle other than the exhaust manifold leak, so I will assume that whomever the new owner is going to be, they will want the steering and braking systems carefully checked and or serviced. If either of them are going to need repairs, better put that into your budget, since it is an unknown. The same goes for the transmission.
Now, I will address the interior of the car. I always wonder why people don't clean things such as the headliner and the welting around the doors. Once again, looking back at my experience with my Miller Meteor, I know that MM used cotton thread to stich the headliner panels together, and that after 50 years, that stitching is starting to fail. The headliner definitely needs to be cleaned, and hopefully, it will not need to be replaced because the stitching of the panels and zippers have failed, but if they have, you are looking at a $1500 repair for replacement.
Not any one of these items is going to be the straw that breaks the camels back, but combined, can add a significant amount to the cost after the purchase, unless you are the type of person that just doesn't care, and will drive the car "as is". To me, I would have addressed all the mechanical issues prior to painting, because safety is more important to me, then a shiny car.
If I were going to buy this car, I would want a lot more pictures of the underneath, and the interior. Then I would decide how much I wanted to be as they say at the auction "all in", and start deducting for those items that I would want to fix. Keep in mind, that whenever we are estimating costs, most times we are guestimating, and the true costs will not be known until all the bills are added up. Usually, it is much more than we had originally thought it would be. I speak from experience, because once you start down that road, you never know what potholes you will experience before you reach your destination.
