Update...
Cary found me some white frosted S & S coach lamps that look great, the previous ones, some clear looking ones, always looked dirty and you could see the bulbs.
New rear coil springs have lifted the rear a bit.
Vinyl top and drapes just waiting on the go order at the trim shop, thought we better get into the body process before we order those things.
The extend table will not secure, rolls back and forth. I have got up under it and the mechanism moves when you pull to the right, but apparently it does not lock. Right now a wheel chock does pretty good, but if any of you engineers have ever dealt with that issue - let me know.
Goes to the body shop Monday, October 7th. I am sending a set of the 1977-1978 Cadillac Fleetwood center disc painted (color of the car) wheel covers, and on standby I have a set of the 1977 Cadillac commercial chassis wheel covers (has small center black disc). The seam in the S & S top split long ago, and with no repair water has seeped in and done it's work. I am extremely concerned about what we will find there.
Here's the offending seam...
