I'm oh-so-happy to address angled shots. Different criteria. Here's mine:
1. Unobstructed views. Honed over 25 years of shooting at car shows. Hella difficult to pull off with hundreds of people typically around. The alternative would be shooting with a 19mm fisheye lens - which curves the entire subject. Given the response, I wouldn't want to be responsible for sending you to the hospital.
2. Picturing entire vehicle as large as possible. (Diagonal allows for a 15% size increase.) This means not cutting off tires, bumpers, etc. *Completely* kills a shot and should be avoided if possible. Not as simple as turning the camera straight; which means stepping backwards another 6-8'. Refer back to reason number 1. Why would I enable even more people to get in the way? Again, most times with other vehicles near it isn't possible anyway.
3. Methodical efficiency. Know how many shots you can take on a full Sony D-Type Lithium battery charge? I do; about 275 without flash - which drops considerably if time passes between shots. Many of the angles aren't more than 10 degrees from 'normal' actually. Sometimes the combined perspective of shooting from knee to ankle (not typical head) height can hang some up. You can stand around a long time awaiting unbeknown sheep to move out of the way. Or, drop low, people see that much faster, and are more prone to obliging.
Soooo...I do not care if someone doesn't like them; nor for instructions; nor what you would do; nor if your neck hurts; nor any lackluster, droll, unoriginal jokes; nor if they're "artsy"; etc. Horizontal shots work best in print applications exclusively where formatting takes priority. If one can't enjoy them as is, skip my posts. Moving on.
Attila: With your keen investigative skills.... you should get a part-time job with CNN or 60 Minutes! It's incredible all the finds you are making! Please keep up the good work, I enjoy.... as I am sure other members are... seeing all these barn (and otherwise) finds you are making! MM
Ha! Thanks..? There is a vehicle equivalent to the show
American Pickers in the works that is scheduled to shoot based in Austin. If so, I'll be a ferret in the field for the host/friend.
There are two more large private stashes I've learned of within the last week. One local friend was turned into code enforcement for too many vehicles. When the enforcer was on the property, a young policeman accompanied. The policeman told my friend (and property owner) that a friend of his father's out in the country has 125 cars from the '30s-'50s he needs to get rid of within the next month. Hilarious irony. Trying to get there next week.
Second stash is about an hour away and has 200 cars, also '30s-'50s. Guy inherited property with the cars on them and isn't into them. He sells reasonably but doesn't advertise and none are visible from any road. Heard he has (had?) a couple hearses. Another day trip as soon as I can fit it.
There are seriously more than 30 coaches I presently know about off the radar. Keep in mind I don't pay attention much to any post-'60. Until both pictures AND price validate (not one or the other), I don't bother mentioning them.
Back to the fleet above. That first coach's chrome band is fuggin' hideous. Coming from a design background, I'd love to meet the person responsible for drawing that up. Looks like it went from thumbnail to fruition; no revision; no critique; no thought. It doesn't flow. The leading edge doesn't line up with anything. And why does it change widths??? All that it accomplishes is making a pressure point. Or providing the recently deceased with a chrome stairway to heaven.
uke2:
