Looking for the standard Superior Ambulance Exhaust Ventilation Fan with the chrome grill. My fan and exterior while roof piece is fine, just looking for the black ring mount frame and chrome grill.
Terry,
Try this site...it should be the original company that made the fans... www.faucher.ca then check in "Ventilation" under products catagory....
That should work for you....
Jim
run it threw the bead blaster and paint it with a little semi black rattle can reseal and put back to gather. that's still way good iron. just looks ugly.
how in heck did they hold the vent on the car?? never see one that bad. stove pipe flange would work for the dam. all it is is a lip to keep water from comming inside
They had a ton of black tar sealer gunked around it, which was probably another source of water intrusion into the medic compartment. I think it was just held in by the tar.
I pulled it all out, cleaned it up, will need to make another wood ring spacer, and hopefully located another frame. Right now it is sealed with the bottom of a pie tin....
Using Jean-Marc's link and graphic, I called Evans Tempco in Grand Rapids, MI.
Great customer service as noted in the post.
Joe at Evans Tempco confirmed parts numbers, and referred me to a dealer just down the street from them as they do not have a dealer close to me in Louisiana.
Spoke to Dave at Comfort Air (616)454-2200 in parts and he was able to price and ship the parts that I need so I don"t have to buy the entire unit.
Hope to have them next week. I wil post pictures upon arrival.
