  #1
Old 07-18-2012, 12:53 AM
James Fischer James Fischer is offline
Website Member
Groaned at 0 Times in 0 Posts
Default Help with mounting a Q2
I would like to ask all the ambulance experts on the board for your input on mounting a Q2......
#1 What if any additional support would be needed to mount it on a 72 Superior hightop ??
#2 Do I need a mounting base or can it sit on top of the fiberglass ??
Those would be the most important questions I guess but if there are any issues that I should know please advise.....
Thanks all in advance....looking forward to your replies !!
  #2
Old 07-18-2012, 12:59 AM
Groaned at 9 Times in 9 Posts
The fiberglass roof isn't strong enough to hold the weight of the Q, and the roof was reinforced on the inside when a external siren was specified on the order. They can be retrofitted with a steel support, however, it isn't an easy job. Check the roof to see if there is already the support installed by the factory. Sometimes you get lucky. If you are looking for a Q, I know someone that has one, but it needs a few dents removed.
  #3
Old 07-18-2012, 08:46 AM
Jean-Marc Dugas Jean-Marc Dugas is offline
Website Member
Groans: 1
I think that the siren support plate was standard in Superior's roof construction.
Assuming that there is no zipper access, you will have to somehow open-up the headliner and look. If your car is set-up the same as the 67 & 69, the easiest spot to do this is where the headliner meets the windshield. You just need to remove the inner windshield trim, take the staples holding the headliner in place out and look in.
I can send you pictures of the set-up from my 67 if you want.
Dieppe, New Brunswick, Canada
Owned in the past
67 Pontiac Superior 48" Headroom
69 Pontiac Superior 48" Headroom
[url]www.youtube.com/pontiacambulance[/url]
[url]http://www.flickr.com/photos/11294884@N03/[/url]
The Following User Says Thank You to Jean-Marc Dugas For This Useful Post:
Paul Steinberg  (07-18-2012)
  #4
Old 07-18-2012, 11:02 AM
Website Member
Thank You !!
I will get out and look as you say....I do have zipper access so hopefully that helps....I would appreciate the pictures if you get a chance to send them.....
Thanks again....
  #5
Old 07-18-2012, 04:25 PM
Website Member
Once you get it mounted be sure to mount the soleniod in the engine compartment. When I mounted the "Q" on the Lifeliner the soleniod was mounted under the dash so when hitting the button I hear this major click. Not too bad since it is only used during parades and such.
Rest assured, there is nothing like a "Q".
The Following 2 Users Say Thank You to Richard Vyse For This Useful Post:
  #6
Old 07-18-2012, 07:09 PM
Dwayne Brooks Dwayne Brooks is offline
Website Member
Groaned at 1 Time in 1 Post
If you decide to not go with a roof mount, a Q2 can fit behind the grill easier than you think...
  #7
Old 07-18-2012, 09:00 PM
Website Member
Quote:
Mr Brooks,
Thanks,I have been told that also.....HOWEVER......If I am going to go with the expense of what a Q costs now days.....its going to get mounted where it will be seen !!
  #8
Old 07-18-2012, 09:10 PM
Website Member
Groans: 1
These pics are from my 69.
This is obviously not a Q, but the principle is the same...
If you have the zipper, you just unzip the flap, and there you have access to the mounting plate for the siren. If not, you need to remove the inside upper windshield trim and carefully detach the headliner.
Here is the plate that support the siren. You can see where the four bolts that hold the siren in place are located along with the speaker wires..
Hope this helps.
Owned in the past
  #9
Old 07-18-2012, 10:14 PM
Website Member
Jean-Marc;
Thank you for the pictures and the pointers...I will now have some idea of what to look for.....
So the Q can be mounted directly onto the fiberglass (with gasket) ??
The other question is where would I get a solenoid ??
Would the one I have for the current siren (Federal 666) work ??
  #10
Old 07-19-2012, 12:08 AM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
the Q can be bolted threw the support. the support will be lining the roof on the inside. so as long as you have the support you may mount it with no othere modifications to the outer skin of the car.
drop in for coffee anytime
Similar Threads
Grille mounting a Q JR Rotramel Emergency lighting and Sirens 3 02-08-2013 12:20 PM
Mounting weather stripping Richard Vyse Technical Discussion Forum 16 02-04-2013 10:56 AM
Siren mounting Paul Steinberg General Discussion Forum 11 08-28-2010 10:07 PM
Spotlight mounting questions Todd Merrifield Technical Discussion Forum 14 05-08-2010 08:32 PM
