  #1
Old 08-04-2011, 12:54 AM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
Default get your parts were you can
I have been getting the lights on the 63 superior. were I'm not positive I thing the center light uses a lens off a 61 comet.
drop in for coffee anytime
  #2
Old 08-04-2011, 12:59 AM
Groaned at 9 Times in 9 Posts
Ford Part number CIKF13450C - 1060-61 Comet tail lamp lens...
John ED Renstrom (08-04-2011)
  #3
Old 08-04-2011, 08:05 PM
Russ Austin Russ Austin is offline
Website Member
Groans: 4
Groaned at 1 Time in 1 Post
The center light to what? Bumper?
  #4
Old 08-05-2011, 12:49 AM
that would be this light here
Richard Vyse (08-05-2011)
  #5
Old 08-05-2011, 01:22 AM
You can always spray the inside of the light with the "chrome" spray paint, or put some aluminum foil behind the bulb holder and keep it in place with some silicone glue. What is the bulb number? I have found some brighter bulbs that are the same size as their less impressive cousins, and have used them. Only thing that you have to be careful about is if the bulb is too close to the lens, then it might melt the plastic.
  #6
Old 08-05-2011, 01:45 AM
David Martin David Martin is offline
Website Member
Groaned at 0 Times in 0 Posts
Ed; You are to be congratulated AGAIN for your obvious attention to detail of your work.
We're very fortunate to have one of your skill and I'm sure Brandon will be ecstatic with the ultimate results.
  #7
Old 08-05-2011, 09:10 AM
Website Member
Groans: 4
Will have to put that info in the "63 need to know stuff" file. Good job John.
  #8
Old 08-05-2011, 12:03 PM
I noticed that these are all 1141s in the lights, so I was able to get the same ones. I thought about putting a piece of tin foil behind it but the light color of the body should be as good a surface to reflect off from. this mechanical flasher runs fairly fast so melting the lens is not a concern. I did notice that there is a separate switch to shut off the flashing rear lights. it turns them to steady burn. I would guess it's to help cut down on the confusion when loading at night. we hope to get the rear glass back in this weekend. I'm letting sealer set up around the frames right now. superior did there usually why that on the glass frames and I'm hoping to be able to cut down on the water coming in. mean time it's get the nail-ons in place and all the hole cover panels back were they go. before the interior gets finished. it's surprising what you find you need. I'm short one piece of the rubber faced jut backed for the drivers compartment. superior cover everything they did not carpet of with that. it's rotted out from the water on the drivers side and in tough shape. just one of those things that no one pays any attention to when they grab that one part off a salvage car. but superior is the only one that used that stuff. lot of things like that are only the one manufacture. each found there own way to solve a problem.
  #9
Old 08-05-2011, 12:16 PM
here is what is under the lens. they took a back up light base off something and chopped it down to fit the bezel they cast to fit the comet taillight. the shape of the backing is what gives you the pattern . everything is just screwed to the fiberglass except the housing it was a nut a bolt. the man that painted it white had tried to remove it to paint and when the nut dropped off the one end he he knew he was in trouble. so he put a dry wall anchor back in to hole to hold it on, rather then pull the headliner loose. then taped around it. leaving the light green for us to match.
Paul Steinberg  (08-05-2011), Richard Vyse (08-05-2011)
Similar Threads
More parts from my "parts car" 75 Caddy Kevin Lynch For Sale To The Public At Large 3 11-21-2012 08:47 PM
parts, parts, and more parts! Attila Bethlenfalvy For Sale To The Public At Large 6 11-21-2011 12:41 AM
Decrease in parts demand and Chinese outsourcing causes Casket Parts Maker to Close Kevin Scott General Discussion Forum 1 01-20-2010 10:44 PM
