  #1
Old 04-02-2011, 12:44 AM
Doug Watson Doug Watson is offline
Website Member
Groaned at 0 Times in 0 Posts
Default why are mirrors not standard cadillac?
So I am putting final chrome on. I had ordered mirror gaskets for my 64 Superior. they are too small. The mirrors are rectangle, not round and the base is longer for both RH/LH. Is the rearview special made as well? It looks too big to fit in a stock cadillac. So who made them for Cadillac/Superior and is this standard throughout all coach mfg, ie MM, Eureka, etc.? Begs the question, if I ever needed to replace one, would it have to be from a donor?
  #2
Old 04-02-2011, 10:43 AM
Bill Carlin Bill Carlin is offline
PCS Life Member
Groans: 7
Groaned at 9 Times in 8 Posts
Is it possible that you have mirrors from a later model Cadillac? From what I understand, Cadillac used round mirrors until sometime in the '70s. Is it possilbe that your square mirrors were put on sometime after the car was built?
The Following User Says Thank You to Bill Carlin For This Useful Post:
Doug Watson (04-02-2011)
  #3
Old 04-02-2011, 11:11 AM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
the 64 used the mirror off the 59 on the CC. the cowl is a 59 cowl also. so there are a couple seals on the cowl and door that are only found on the 59 car. just one more of those odd things you find on the early 60s. it has to do with how the stock mirror manuale adjuster went inside the car. remember superior made the doors using the front half of the 59 door frame. the 64 door frame is a different shape to accommodate the adjuster they used on the mirror. I was hoping to avoid plaiting the one we have here by getting a diffeent on . thus I learned my lesson.
drop in for coffee anytime
  #4
Old 04-02-2011, 11:35 AM
Tom Hoczyk Tom Hoczyk is offline
PCS Past President
Mirrors on any of our cars is always a very sore subject. This especially applies to the '59-'64 Cadillac model years with the dogleg windshield. Trust me when I say, there is not such thing as a good mirror, only those that are less bad than others. Worst of all, if you were to purchase an OEM style mirror from McVey or Ed Cholakian, it would look great, but you'd have to have a weird twist in it to be able to see anything. Even at that, you'll only see half of what you'd like. That's the case with my '60 Eureka.
I actually have two mirrors on the passenger side door. One is the standard Cadillac mirror that is mounted to the sheet metal of the door, the other is aftermarket, clamped to the upper edge of the door. It's not the prettiest, but beats having the side of your car bashed in when you're involved in an accident because you couldn't see what's on the right. See photo below for reference. By the way, that's not me in the photo, just some admirers in downtown Des Moines during the 2006 CLC Grand National. Tom
  #5
Old 04-02-2011, 11:43 AM
Russ Austin Russ Austin is offline
Website Member
Groans: 4
Groaned at 1 Time in 1 Post
I thought all the CC cars used the long stem rear view mirror. Found a 63 uperior in a salvage yard with a short stem rear view mirror installed.
The Following User Says Thank You to Russ Austin For This Useful Post:
  #6
Old 04-02-2011, 11:49 AM
Website Member
Groans: 4
What else is there to know about parts interchangability on the 63/64 CC? I know the rear license plate lense on the 63 Superior are from a 55-56 chevy wagon.
U-joint U bolt; Neafco, 1-0189
Rear u-joint; same as front.
  #7
Old 04-02-2011, 05:27 PM
Brad Ross Brad Ross is offline
PCS Michigan Chapter President
Quote:
From my observations, most commercial chassis cars did have the long stem rear view mirror, but I have noticed some exceptions. For example, Dan Skivolocke's 1959 Superior ambulance has a short stem mirror. After noticing this, I realized that a long stem mirror would be useless in that car because of the partition.
1988 Superior Cadillac Sovereign Brougham
  #8
Old 04-02-2011, 06:32 PM
Groaned at 9 Times in 9 Posts
I believe that there are 2 different type of mirrors being discussed in this thread. The original question was in reference to the outside door mirror, and the associated door mirror gasket. Brad, you have brought into the discussion the inside rear view mirror, I believe. Please correct me if this isn't what you are referring to. If it is the inside rear view mirror, then the mirror itself is the same for many years, and the only way to tell the vintage is if it is a day/night mirror. Then the "lever" to change from day to night changes design every few years, however, the function remains constant. The mirror bracket that GM supplied for the commercial glass cars is a long neck bracket, however, as you have pointed out, a short neck bracket might be preferred in some instances.
As for the outside door mirror, I believe that GM provided a special mirror for the commercial chassis cars that looks like the GM mirror used on the same year Cadillac, but isn't the same. Only checking the Cadillac parts manual will give a definitive answer to this question as to which years this option was available.
  #9
Old 04-02-2011, 06:40 PM
Shawn Blyler Shawn Blyler is offline
I know that the outside door mirror on the passenger side on my Fleetwood 75 is different than the standard mirrors on the other models, must be angled differently due to the car being longer. Also, the inside rear view mirror is also different, is is wider than the regular cars. I just had new mirror glass put in the passenger side mirror last week. It will be nice to actually see something over there other than four pieces of broken mirror glass, all reflecting something other than what you need to see. The glass that fit was exactly the same size as a '79 Sedan DeVille. All done for $32.00.
1968 Cadillac Fleetwood 75 9 passenger Sedan
  #10
Old 04-03-2011, 12:12 AM
rubber the right way has the gasket you need
Similar Threads
Cadillac mirrors Richard Vyse Wanted 6 02-19-2013 09:38 AM
Standard vs Standard Extra Jean-Marc Dugas Period Correct Discussion Forum 1 02-12-2011 09:49 PM
WANTED, Side Mirrors For a 1971 Cadillac Josh Gentry Wanted 3 01-08-2011 08:36 AM
WANTED: Mirrors Dwayne Brooks Wanted 11 07-21-2010 02:28 PM
Commercial VS. Standard glass John Royark JR General Discussion Forum 1 11-15-2009 11:54 AM
