  #1
Old 02-21-2011, 10:35 AM
Chris Elzie Chris Elzie is offline
Website Member
Groaned at 0 Times in 0 Posts
Default Headlight
My headlights on my 75 Superior ambulance only work on high beam and its not all four lights that come on just the inside 2, would that be a dimmer switch?
  #2
Old 02-21-2011, 10:38 AM
Website Member
Quote:
Interesting situation. Do the low beams come on when you don't have the high beam ons? Where's Ed to get his thoughts.
  #3
Old 02-21-2011, 10:59 AM
Todd Merrifield Todd Merrifield is offline
Website Member
Not sure when they started doing it, but on most of my four-headlight GM vehicles the low beams go out when the high beams come on. I can't remember what my 62 did, but I think it was the same way. Sounds like something is amiss in your low beam circuit.
  #4
Old 02-21-2011, 11:25 AM
Website Member
Quote:
On my 73 before adding the red headlights, when activating the hi-beams all fours lights stayed on.
  #5
Old 02-21-2011, 12:02 PM
Website Member
You may be right. Now that I think of it, I think I have a picture of my old 69 wagon with all four headlights on. I don't think I modified anything for it to do that. I know the 90's pickups only ever have two lights on at a time, high or low.
  #6
Old 02-21-2011, 12:06 PM
Bill Leverett's Avatar
Bill Leverett Bill Leverett is offline
PCS Member/Super Site Supporter/Paramedic Supervisor
Groaned at 1 Time in 1 Post
Hi Chris...I had the same problem with my '73 Lifeliner. It was the floor dimmer switch. I pulled it off, cleaned all the contacts and made sure the wires were insulated well between each other and the floor after making the reconnections.
Electricity will do strange things when circuits are not "clean" and the ground is intermittent.
Good luck
Bill Leverett
1953 Pontiac/Barnette Combination
  #7
Old 02-21-2011, 12:36 PM
Raymond Armstrong Raymond Armstrong is offline
Junior Member
Just checked the 75 thats been sitting a while. On high, only 3 lights came on, pumped it a few times and all 4 came on, so the dimmer switch was probably crusty.
  #8
Old 02-21-2011, 01:45 PM
Default From my 1972 Shop Manual
Chris...here is a page from my 1973 Shop Manual. I'd really suggest that you try and find one for your car...saves alot of grief and at least sends you in a reasonable direction for trouble-shooting.
Bill Leverett
The Following User Says Thank You to Bill Leverett For This Useful Post:
Jeremy D. Ledford (02-21-2011)
  #9
Old 02-21-2011, 04:05 PM
Groaned at 9 Times in 9 Posts
With the introduction of the halogen headlamp bulb units, there was a short period of time that the cars started being wired so only 2 of the 4 bulbs were illuminated at any one given time.. The interesting thing is that they just didn't use the high beam headlight circuit on the outer bulbs, and they just had two terminals hooked up to the 3 terminals on the bulbs. It would be an easy fix if your car was wired this way, by just installing a jumper wire from the hot wire on the high beam bulb (inner) to the high beam terminal on the low / high beam bulb (outer).
Bill Leverett (02-21-2011)
  #10
Old 02-21-2011, 05:27 PM
Website Member
what is happening is when I turn the lights on the inner two most dont come on unless they are on high, but when on high thats when the inner two some one but the outer 2 do not.
Similar Threads
Wanted - Headlight switch Patrick J. Martin Wanted 2 11-12-2012 03:33 PM
55 cad headlight bezels Rocky Fluegge For Sale To The Public At Large 0 04-22-2012 11:28 PM
headlight low beam Doug Watson Technical Discussion Forum 4 03-01-2012 12:19 AM
wanted; headlight trim Russ Austin Wanted 5 06-11-2011 11:11 PM
