  #1
Old 08-24-2010, 02:25 PM
Rick Franklin Rick Franklin is offline
Groans: 16
Groaned at 7 Times in 6 Posts
Default purple high beam headlites
anyone know where i can get a pair of purple rectangular high beam lights for my Lincoln? It uses a 4 lamp system. I also need/want a "wig -wag" unit, but Im assuming I can order that through Galls or one of my towing supply catalogs.
........1986 Lincoln S&S Landau Funeral Coach with extendable table...............
  #2
Old 08-24-2010, 02:30 PM
Mark Trask Mark Trask is offline
Groaned at 0 Times in 0 Posts
Default Purple high beams
Hi Rich,
Here is a link for you.
http://www.hearseclub.com/store/purpleheadlights.htm
Mark
  #3
Old 08-24-2010, 10:41 PM
Douglas Smith Douglas Smith is offline
Website Member
I recently saw a purple HID kit on a hearse
  #4
Old 08-24-2010, 11:23 PM
W David Bessant's Avatar
W David Bessant W David Bessant is offline
I just received a set from that very same link, it took a bit of time with customs and all but I am simply delighted. I will try them on the road this week maybe......just for a drive and see if I get pulled over.
I would also like a wig wag device......if anyone can help.
Dave
  #5
Old 08-24-2010, 11:31 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
three way or alternating flasher at any parts store. you can ask for a wrecker one to sometimes that jogs there memory as to what you need.
drop in for coffee anytime
W David Bessant (08-24-2010)
  #6
Old 08-24-2010, 11:45 PM
Groaned at 9 Times in 9 Posts
You can get purple glass paint at any hobby or craft store, and paint your bulbs. If you don't like the results, you can clean it off with some brillo pads. The paint is under $5 and sometimes you can even find it in a spray can.
Doug Kelley (08-25-2010), W David Bessant (08-24-2010)
  #7
Old 08-25-2010, 10:41 AM
Website Member
Dave
I used this on my 73 Lifeliner for the headlights. Real simple to hook up. Power in on "X", one line "L" to one headlight and "L" to the other headlight. You will need to ground them. Yuo can get at NAPA for about $23.
The Following User Says Thank You to Richard Vyse For This Useful Post:
W David Bessant (08-25-2010)
  #8
Old 08-25-2010, 11:23 AM
Don't forget to buy the connectors for the headlamps, so you don't have to butcher up your wire harness if you decide to put it back to original. They cost about $3 each and are a bargain compared to what a replacement wire harness costs...
Richard Vyse (08-25-2010), W David Bessant (08-25-2010)
  #9
Old 08-25-2010, 01:29 PM
Website Member
Is that one you can turn on and off and still use the high beams like normal or is it one that only comes on when the high beams are on?
  #10
Old 08-25-2010, 02:11 PM
Website Member
Quote:
Only comes on using a seperate switch, no high beams. I have mine working off the switch panel inside the ambulance. Paul is right, buy a set of connectors so you do not butcher the wiring system on your car.
Similar Threads
High top vs Low Top Bruce Biancalana General Discussion Forum 21 07-12-2012 01:32 AM
headlight low beam Doug Watson Technical Discussion Forum 4 03-01-2012 12:19 AM
Wanted- Superior Sealed beam bulb holders. Cliff Bergum Wanted 3 12-08-2010 02:50 AM
Looking for a sealed beam... Todd Merrifield Technical Discussion Forum 11 09-14-2009 05:29 PM
