  #31
Old 01-31-2018, 11:11 PM
Website Member
Groaned at 0 Times in 0 Posts
Went to pick up the hearse tonight. They gave me the key, said they tied the choke off and it should start right up.
Started it. Idled a few minutes but it died as soon as i hit the gas. Tried several more times then it just wouldnt start. They came out and messed with it a minute and the guy that set the choke said "see? Its jot going to run with the choke open, demonstrating as he throttled it and it would die.
So firstly i was annoyed that they ziptied the choke open and didnt even bother to test drive it or make sure it runs.
Then went in and asked if someone could help me get the ziptie off to drive it. They just handed me a pair of scissors. Messed with it for 15 min, unable to cut it off with a little pair of scissors, before i went in and someone got some actual wire clippers to cut it off for me.
It IS running better now simply because they brushed off the plugs but im most certainly not going back.
Spark plugs are black so i will be replacing those. I researched and determimed fancy platinum or iridium plugs are a bad idea and will be getting copper ones, but can anyone tell me the proper plug gapping for the 68?
1968 Cadillac MM Combination
  #32
Old 01-31-2018, 11:32 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
Ok you can not worry about the plugs. they will clean off as soon as you can drive it without it flooding but the problem is not just the choke. it will not flood with the choke open. like I said put the old carburetor back on. I betting they did not put the tin plate back in and it has burnt threw the center of the gasket. it would then let exhaust gas go into the intake and case it to lean out and stall.
remember you had someone drive this car before you brought it, it ran fine for them. your problems started when you pulled into that shop.
drop in for coffee anytime
  #33
Old 02-01-2018, 12:10 AM
Groaned at 9 Times in 9 Posts
.035... thirty five thousands... Point gap is .016 or 30 degrees of dwell. Timing has to be set with the car in neutral, and the parking brake release vacuum line removed and plugged. Don't remember exactly, but I think that the timing is 8 degrees before TDC. (top dead center).
  #34
Old 02-01-2018, 10:24 AM
Website Member
Quote:
Thanks, and im not going to trust that the previous owner put the correct plugs in it anyway, so im not going to compare it. I want to make sure I'm buying the recommended OEM plugs. Can anyone give me a suggestion. I googled spark plugs for a 68 cadillac engine and some sites tried to say I needed double platinum which I KNOW is grossly incorrect
  #35
Old 02-01-2018, 12:40 PM
I would use whatever the recomended AC plug is or its interchange no need to get exotic, I also would leave plugs alone unless they foul out again. A recent go round with my wifes Audi A8 shows how this goes everywhere. Problem on recent 100 miles round trip car picked up a dead miss. My Snap On scanner will not talk to this Kraut car I call my godson (Foreign car nut) where do I take this? he tells me of shop that is "reasonable". We go next day less than 24 hours later the call comes all fixed $520.00 YIKES!!! The charge includes two new coil packs ($52.00 each) and Eight new spark plugs @ $20.78 each. Now lets get real here at home had my scanner worked the REAL story is there was a bad coil pack just like my Crown Vics get and that would have done the job for less than $52.00 due to trade discount. Trust me I am getting a scanner that will read kraut cars. One repair here will pay for the scanner.
  #36
Old 02-01-2018, 05:38 PM
Website Member
Got some ACDelco plugs during lunch today. I may take a look at one of my current plugs to see how they look and keep these in the coach. Shop made it sound like these plugs were barely firing. If it starts fouling again I will start replacing
  #37
Old 02-01-2018, 10:25 PM
No you need to fix the reason they are fouling. Fouling is a result of another problem. From the discussion it's flooding. Fix that problem clean and regap the p!ugs and you will be good to go. Replacing the plugs now will most likly only result in the new ones soon fouling.
Now my stead fast rule when you have trouble like you are is to go back the the last thing you fixed before the problems started. You then correct what was done wrong then.
Denny Shira (02-06-2018), Peter Grave (02-01-2018)
  #38
Old 02-05-2018, 11:09 AM
Website Member
Your right, problem seems to have started with this "new" carburetor. I do have a spare set of plugs ready to go, but not installing yet. As soon as I can afford it I will send my old carb to be rebuilt. I think I have a vacuum leak now though. Drove it Sunday and its whistling loud from the engine, When its warm enough again I will see if I can find any broken hoses
  #39
Old 02-05-2018, 12:06 PM
The biggest part of any tune up is fix the vacuum leaks. But if you heard it driving it's a big one and probily the source of your problems. Low vacuum will cause it to run rich.
Denny Shira (02-06-2018), Peter Grave (02-05-2018)
  #40
Old 02-06-2018, 06:19 PM
Website Member
And now its whining when accelerating. Odd that all these problems started after getting it back from the shop. Still not going back there though
