  #11
Old 09-07-2017, 11:10 PM
Groaned at 9 Times in 9 Posts
Just for the confirmation of fitment, put the original doors back onto the car, and see if you can fit them. Then compare the fit of one side with old doors, with the other side with the new doors. Whatever is different, should become evident quickly by looking from side to side.
  #12
Old 09-07-2017, 11:15 PM
John ED Renstrom's Avatar
PCS Elected Director
Groaned at 3 Times in 3 Posts
shim the read door hinges. you can cut them out of a flat piece of steel the proper thickness. that is guessing that they are not front opening doors.
the other fix is to remove the door and grind down the offending edges and then weld the lip back up. or
rat tail file and make the slots in the hinges longer the direction you need to go. a 1/8 in on both doors is a lot
or a combination of both. this is why I have never tried to change a door but would rather fix what I have. they are each one custom fit not mass produced.
but unless they are over laping and they both open and close with other one closed you may be as good as it gets.
drop in for coffee anytime
  #13
Old 09-08-2017, 01:13 AM
Jacob M. Fournier's Avatar
Jacob M. Fournier Jacob M. Fournier is online now
Groaned at 0 Times in 0 Posts
Chris - I measured all three of my '76s and had a friend measure a '73 - 52 1/2" on the front door, 45 1/2" on the back door (even my '67 is 45 1/2" on the back door) - but a couple of the doors are as much as 1/4" larger. One thing I did not check between the '76 and '73 - I did not look to see if there was a difference in the construction of where the hinge mounted - but if you want I can check my cars for that this weekend.
1967 S & S Cadillac Professional High Body ambulance (Billings, MT Ambulance Service)
1976 S & S Cadillac Professional High Body ambulance (Bloomsburg, PA Volunteer Ambulance Association)
1976 S & S Cadillac Professional High Body ambulance (Roxbury, NJ Chemical Engine Co. #2)
1947 A. J. Miller Cadillac Duplex combination
The Following User Says Thank You to Jacob M. Fournier For This Useful Post:
Paul Steinberg  (09-08-2017)
Similar Threads
2000 Cadillac commercial glass measurements? Noah Dorsey Technical Discussion Forum 6 11-04-2015 01:07 PM
GAS cap HELP needed...... James Fischer Technical Discussion Forum 22 01-15-2013 01:47 PM
One man cot needed Pat Post Wanted 2 01-31-2012 02:13 PM
Help needed! Rick Duffy Period Correct Discussion Forum 3 11-13-2009 05:59 PM
