Technical Discussion Forum For the discussion of technical questions about Professional Cars and their repair and maintenance. Posting in this forum is limited to PCS Members and / or Site Supporters. We encourage all website users to become members of the Professional Car Society and / or become Site Supporter. |
Thread Tools | Display Modes |
#1
this comes up every now and them. what color was the paint they used on the wheels. first of all it was not paint but the factory sealer/primer. most of your cars come from the days of wheels painted to match the body color. as the coach builders ordered incomplete cars the wheels went out unpainted.
after cleaning up the set I got from Kurt and the spare in the bead blaster I have colored them as close as I can get to the factory primer. Rust-Oliem has a change in there paint out that is really easy to spray. as luck would have it when I grabbed the two cans I got two different versions of it. I sprayed the first set with the primer gray and only got half of the last wheel before we had to brake out the other can. as they say there is no luck like dumb luck. the primer gray is way to blue to match the semi gloss primer/paint gray is as close as you can get. needless to say the first set now match the last one
drop in for coffee anytime |
#2
I don't believe that it was primer, but a single stage enamel that had a semi gloss to it. If they were primer, they would have rusted, since primer is porous.
"When a man opens a door for his wife, it's either a new car or a new wife." |
#3
It's the standard sealer GM sprayed on all there panels , that is why they are rusty.or as in this case the supplier for GM put on. Your laquer base primers are the ones that soake up water like a sponge. But none are designed to be the only finish. Not ever the factory sealers. They are designed to protect the steel untell! A finish cost is applied. You can tell the sealers buy the semi gloss finish and the slick feel. Think replacement fenders. Now the new panles that Kurt picked up from Carl are primed. But remember they were not stamped by GM.
#4
now as long as I have the two different wheels off lets see if there is a different off set to them. turns out to be 1/8 of a inch. not enough to worry about
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
A Little Autumn Color.... | Cary Livingston | General Discussion Forum | 3 | 10-25-2014 08:06 AM |
Cadillac color | Mike McGeehan | General Discussion Forum | 7 | 12-14-2013 10:53 PM |
What is your color preference? | Josh Gentry | General Discussion Forum | 35 | 09-29-2011 10:42 PM |
name this paint color | Attila Bethlenfalvy | General Discussion Forum | 12 | 07-21-2011 02:22 AM |
color has been chosen | John ED Renstrom | General Discussion Forum | 4 | 09-21-2009 11:42 AM |
