  #41
Old 06-23-2017, 11:54 AM
Groaned at 0 Times in 0 Posts
Richard the resistance built up with corrosion in the JUNK gypsy terminal ends is the issue. If you take them apart you are going to find I am sure white powder mixed in with the copper cable strands. The Ford truck mentioned in the earlier post had a burned melt spot in one place where it arced trying to make contact with the gypsy terminal end. Your problem is the gypsy terminal ends THEY ARE JUNK!!!! There is no other way to put it. Find a heavy truck repair shop in your area that makes battery cables for big rigs have them put proper ends on your cables the problem will leave. DON'T pull the starter the chances of it being the issue are VERY SMALL. The fact that you have gypsy terminal ends on EVERY CABLE to the batteries it is a wonder you have not had a fire. You have a beautiful rig make you battery cables match the rest of the rig. Over the years I have had more Triple A calls for dead battery where the battery was not dead but the JUNK gypsy terminal ends were corroded.
Richard Vyse (06-23-2017)
  #42
Old 06-23-2017, 12:09 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
Batteries are big enough. You connections​ are poor. I'll bet you coffee that if you go out and buy 4 new battery ends like the ones you have clean up the wire ends and replace the terminology ends with the new ones it will work better for a time.
That is just the nature of them. If you go out and buy the compression ones as suggested they will last longer. If you have ends soldered on it will be a perment repair.
As for the wires coming off the positive post of the batteries . The cable is most likely your mechanical siren. The black one on the other post a charge wire. The red one with the fuse I'm betting is the relay for the blower on the AC unit. None of these would work untell they were energised with power to do that coming off the ignation Which gets it's power from the machanical switch.
The question I would have is the red wire should go off with the switch and if the other is the charge wire it only direct to one battery. This gives the other on a round about way to receive o the charge.
The car should start easily on one battery. Either one. And run on that battery all day long. From what I see if you have it on the left battery. It would not charge . That one will only get a charge if the switch is in the dule position.
The task of the Cole hearse switch is to be able to shut off all power to the car. There is a tap in the back that will allow you to bypass it for power to the clock. If you bypass the switch to supply power you defeat this purpose
drop in for coffee anytime
  #43
Old 06-23-2017, 01:34 PM
Website Member
Thank you guys and appreciate all the in put. I will work on replacing the cables with the proper ones. Today I go out to test start her and it fires right up on Battery #1. No drag just crank right up.
Thanks again.
  #44
Old 06-23-2017, 09:32 PM
So how about battery number two? Which one is one the right or left?
  #45
Old 06-24-2017, 11:48 PM
Groaned at 9 Times in 9 Posts
DISCLAIMER: The opinions posted to this thread may include information from sources that may or may not be reliable and facts that don’t necessarily exist. All comments should be considered satirical and any and all quotes attributed to actual experts are complete and total nonsense. Pictures that represent actual car batteries should be considered altered and not in any way real.
John ED Renstrom (06-25-2017), Richard Vyse (06-27-2017)
  #46
Old 06-28-2017, 01:57 PM
Website Member
I had both batteries tested and they are strong. Turns out it is my battery switch. Took switch apart and jiggled wires and played with switch and got a good connection therefore it cranked right up on Battery #1. So I think I'll switch out the switch. Will this switch work on the Lifeliner? The last switch I purchased was a used one for $15 off eBay.
http://www.ebay.com/itm/Cole-Hersee-...ZZQZfz&vxp=mtr
  #47
Old 06-28-2017, 03:06 PM
If it looks like your original switch, then yes. If different, then you might have to deal with mounting holes, etc..
Richard Vyse (06-28-2017)
  #48
Old 06-28-2017, 08:23 PM
Kurt Arends's Avatar
Groans: 7
Groaned at 1 Time in 1 Post
Stick with a period-correct switch. The switch in the photo is not. You will get points deducted!!
  #49
Old 06-28-2017, 11:27 PM
it always pays to play with everything.
  #50
Old 06-29-2017, 08:05 AM
Website Member
Quote:
Only thing I can locate are used ones. Not sure why they go bad. Turns out it is a simple wiring process. Hot side in from each battery then a single hot cable to the starter. Since I've always left this up to someone else to repair replacing the cables is not such a big deal after all. Just need the proper length, next project. But in the mean time I did replace the cables ends and cleaned up the cables adding protective gel as well.
The Following User Says Thank You to Richard Vyse For This Useful Post:
John ED Renstrom (06-29-2017)
Similar Threads
slow news day John ED Renstrom General Discussion Forum 3 12-29-2014 12:44 AM
A casket crank can be handy Danny Ryder General Discussion Forum 15 03-25-2013 12:55 PM
slow man at work John ED Renstrom General Discussion Forum 25 06-16-2011 06:23 PM
Friends site slow.... Richard Vyse General Discussion Forum 5 07-10-2009 11:00 AM
Slow turn signals & headlamp flasher Richard Vyse Technical Discussion Forum 8 05-04-2009 12:57 AM
