  #1
Old 01-10-2017, 09:53 PM
Nicholas Studer Nicholas Studer is offline
Groaned at 0 Times in 0 Posts
Default Trim Ring for 1970 Cotington Center/Auxiliary Tunnel Lights?
For main update thread: http://www.professionalcarsociety.or...ad.php?t=16134
The trim rings for my 1970 C/B-Oldsmobile Cotington 48 were in less than stellar shape, so to the plating shop they go! The four large tunnel lights (2 front, 2 rear) were reasonable and just need some cleaning/plating. For whatever reason, the two center "auxiliary" lights in the middle were far worse. These smaller ones actually hold a parabolic reflector with a glass lens - not a GE 4001R bulb like the others. One had a ton of rust on the inside, but seemed sound and hopefully will clean up. The other - well, let's just say that basically half of the 6 O'clock end is rotted out. It may be possible to patch it, but I'm doubtful.
Is there a current source for these smaller trim rings, or might anyone have a few lying around? It appears to be PAR36 size, with approx. 4" of a central cutout.
  #2
Old 01-10-2017, 10:03 PM
Kurt Arends's Avatar
Groans: 7
Groaned at 1 Time in 1 Post
Will do some digging this weekend when I get home.
  #3
Old 01-11-2017, 04:19 AM
Groaned at 9 Times in 9 Posts
I wouldn't just send them to just any plating shop, but one that specializes in metal restoration and repair. It won't be cheap, but it will be done properly. A shop that just does chroming, will attempt to buff out the rust, and in the end, you might get back a part that is in worse condition than when you sent it. I would hate to see your car all finished waiting for you to find a suitable replacement. Chances are that a good replacement is going to be extremely hard to find, since these parts almost always rust the same way on all the cars. I send all my next to impossible to replace parts to QualKrom, in Eire PA. They have never lost a part, and it is always repaired to like new condition. For run of the mill other parts, I use a few other less expensive platers. You are in the final stretch of the cars restoration, and now is not the time to start skimping on quality, where it counts so much and will be so visible.
Nicholas Studer (01-11-2017)
  #4
Old 01-11-2017, 10:52 AM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
With out looking on the back side it looks to be the standard unity ring. Is you hand covering the screw hole? Surprising enough most of this stuff has been made recently in the farm implement category. But sadly enough thay are going to the LEDs also. Those lights may be the lenes I'm looking for on my 53. The lens would be around 4&7/8 just under 5 inches in diameter. But there trim ring is split and uses a set screw that pinches it around the housing on the bottom. One can look in the grott line it might be cheaper to buy a new light for the ring then get that one repaired. If it's a unity ring I should have one up here if Kurt can't find one. Flip it over and show the back side. Also how deep is it.
drop in for coffee anytime
  #5
Old 01-11-2017, 06:55 PM
Quote:
Thanks!
Quote:
Agree! Won't be skimping on this. The shop I am using is well-known in the area for metal restoration. Have not had them start on the small rings just yet. The large rings are in generally decent shape and mostly just need plating.
Quote:
Yes, there is indeed a screw hole under my thumb. Another photo with the glass shown. I'll get a depth and photo of the back.
  #6
Old 01-11-2017, 08:53 PM
These were most likely of from a much older car and placed on it when in service.
  #7
Old 01-11-2017, 09:33 PM
I am unclear on why would you think that? Can you explain further? Two or three of these lights are on nearly every 1970 Cotington 48 I have been able to find photos of, to include the one on the cover of the brochure.
Warning equipment isn't listed in the "standard" features list - but it's fascinating how all Cotington 48's were basically identical in setup and paint color.
The Following 2 Users Say Thank You to Nicholas Studer For This Useful Post:
Richard Vyse (01-12-2017), Steve Loftin (01-12-2017)
  #8
Old 01-11-2017, 10:27 PM
Groans: 7
Nick,
Is there a manufacturer's name stamped into the top of the steel cylinder just behind the ring on these?
The Following User Says Thank You to Kurt Arends For This Useful Post:
  #9
Old 01-11-2017, 11:36 PM
Nick,
Interesting question! That would require a close look at those tunnels - which are not in my possession. I'll check at first opportunity I have - but especially with the corrosion I am not sure it'll be visible if so.
  #10
Old 01-12-2017, 12:23 PM
That style of light is Older then the car. Had they been put on in the factory they would have used the same sealed beam set up as the front tunnels. It is most likely hen that the service did the add on lights. The aperance would be the same as the flyer but a close exam of different would show that the trim ring on the lights would be the same style.on all 6. It also explains why they are in worse shape. But the only way to say either way would be if all the other 70s have the exact same glass lenses, bulb and reflector light on the front roof and sealed beams front and rear courners. As I don't have one to look at it's a educated guess on my part based on my current experance level. That if it came out of the factory all the par 36 lights would be the same set up. One check is the lens it will have a two digit number cast into it that will be the year of manufacture. If it has a part number it's the last two.
Similar Threads
Update on 1970 Cotington 48 Nicholas Studer General Discussion Forum 115 04-22-2018 01:17 AM
MM pod tunnel lights tag, 70's Channing Spencer eBay Listings Discussion Forum 4 04-20-2016 05:12 PM
Front tunnel lights, including the tunnel! Kevin Lynch For Sale To The Public At Large 4 01-18-2016 09:52 PM
Help ID'ing Superior light housing/trim ring James Fischer Technical Discussion Forum 3 09-25-2012 09:12 PM
