  #1
Old 08-30-2015, 05:17 PM
Mike Owens Mike Owens is offline
Groaned at 0 Times in 0 Posts
Default Red Headlights
Where can I buy replacement red headlights for my 1970 Superior Cadillac Ambulance? What are the specs I need to know?
  #2
Old 08-30-2015, 09:45 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
they are a standard high beam light with a red instead of white lens. the number would be followed by a R now don't quote me but i think it was Kurt that had a few for sale
drop in for coffee anytime
  #3
Old 08-30-2015, 10:33 PM
Kurt Arends's Avatar
Groans: 7
Groaned at 1 Time in 1 Post
Still have a few rounds and many rect. available.
The Following User Says Thank You to Kurt Arends For This Useful Post:
Steve Loftin (08-31-2015)
  #4
Old 08-31-2015, 03:10 PM
Kevin O'Connell Kevin O'Connell is offline
PCS Life Member / PCS So Cal Chapter President
The part number is 4001R. Wagner also made a 50 watt version using part number 5001R. You should bear in mind that Federal Motor Vehicle Safety Standards prohibit altering the factory headlight system. People get away with it all the time but if you need to use your high beams you're out of luck.
The Following 2 Users Say Thank You to Kevin O'Connell For This Useful Post:
Kurt Arends (08-31-2015), Steve Loftin (08-31-2015)
  #5
Old 08-31-2015, 04:30 PM
Groans: 7
What I have are 4001Rs(round), and H4541Rs(Halogen rect.).
John ED Renstrom (08-31-2015)
  #6
Old 08-31-2015, 10:14 PM
Stephen Mayfield Stephen Mayfield is offline
Website Member
Groans: 1
Talking
Or,if that doesn't work, you could call the Grave Digger Monster Truck team in North Carolina... I'm sure they have tons you could use...LOL
  #7
Old 09-02-2015, 04:44 AM
I finally got the headlight out and it has the following printed on the back: 12 Volt GE4413R
  #8
Old 09-02-2015, 08:47 AM
Groans: 7
Quote:
4413R is not a headlight. It has the screw connection base, not the 3-prong hi-beam connection. The 4413Rs would not have been correct, if mounted in the hi-beam headlight position.
  #9
Old 09-02-2015, 11:01 AM
so would the 4413 be a fluted lens or just a spot? the par 36 bulb is the same size in diameter as the headlight it lacks the mounting tabs to keep it from rotating and is as you have discovered wired differently. with any kind of luck the man that put them in knew enough to wire them competently separate from the headlight harness. so that set of wires is intact. that begin said when i was looking for bulbs this size in red for the suburban I was able to find them made in china in spots only. some were in the 15 buck range. type in par 36 red light in your search bar, see what pops up
  #10
Old 09-02-2015, 07:49 PM
Groans: 7
Quote:
Ed,
Yes, the 4413R is fluted.
John ED Renstrom (09-02-2015)
Similar Threads
purple headlights Mike McGeehan Emergency lighting and Sirens 7 11-02-2013 12:21 PM
72 Pontiac Headlights Terry Broussard Technical Discussion Forum 28 03-25-2013 06:24 AM
1976 S&S headlights all out! Tom Hoczyk Technical Discussion Forum 14 11-13-2012 09:12 PM
Wig Wag Alternating Headlights Terry Broussard Period Correct Discussion Forum 2 01-08-2011 03:03 PM
Headlights Jean-Marc Dugas Technical Discussion Forum 5 09-21-2010 10:27 PM
