You can call 9-9 PCT. email = djscully@charter.net or PM Thanks
53,700 original miles . P/S , P/B , A/C, Auto Trans,. Power Seat,Power Table
Interior original , other than seat redone.
Factory A/C
A color you do not see too often on a coach (Sandalwood)
429 Cid ,Turbo 400 Trans.
Table Works Perfect
Ignition , Door and Glove Box Keys.
New Windshield.
New Lt Outside Mirror
Plugs , Valve Cover Gaskets , Fuel , Air FIlter Replaced
Oil change and Filter.
Runs and Stops.
All bier pins present.
No Breaks in the plastic ends on the table.
All 5 rims are the correct commercial style rims, and jack
Clear Title in my name.
On a Non Op , no back fees. If purchased in Ca
Always a So Cal Coach.
Dead paint , great chrome, stainless and bumpers
0 Rust , solid frame and body.
Needs the obvious paint.
Dash Pad cracked ( These are available in reproduction)
Steering box needs resealed. ( Works no problem just seeping )
Needs Turn Signal Switch ( Good used one comes with it not installed)
A/C complete , but not operational .
Old Tires just good rollers.
Has been sitting for a few years .
Brakes etc would have to be checked and serviced before putting it on the road.
Top of the inside door panels are toast , comes with used door tops to help in that repair.
Curtains are there , but only good for patterns.
All Curtain Rods and Holders are in place.
Wind lace needs replacing.
Load Door Glass has some scratches , needs to be polished out.
Rt ¼ trim out being straightened
Lt B pillar trim there , needs reattached
Rear load door panel , out being repaired
Seat out being reupholstered
Slight exhaust leak at rt manifold , needs gasket.
Small Tear in headliner by rear load door.
Factory A/C
Table Works Perfect
New Windshield.
Runs and Stops.
