1996 Cadillac Fleetwood by Eagle Coach
1996 Cadillac Fleetwood Hearse by Eagle Coach. This hearse was just retired in April 2020 from a Massachusetts funeral home. The quality and https://www.ebay.com/itm/1996-Cadil...tem2ae7844f44:g:bIcAAOSwvXReqHD3craftsmanship of Eagle Coach Co. is evident in this hearse. Eagle Coach used fiberglass when converting their vehicles into hearses, so their bodies won’t rust. It was garage kept. Look how clean and visible all the radio and heat & a/c buttons are! This hearse is equipped with emergency lights for funeral processions. Battery is currently good; however it is coming to the end of its lifespan. Driver door lock works manually; however the power door locks on the driver’s door does not work (the switch on the door works). On the bottom left of the rear bumper rust is starting to bleed through the chrome (see picture, it’s not bad yet, but will need future attention). AC worked great last summer blew ice cold air; with the cold spring Mass. has had, I’m unable to effectively test the AC now. I assume it still works great. New brakes were installed in 2019 and new tires in December of 2017. Always meticulously maintained including oil changes every 3000 miles.https://www.ebay.com/itm/1996-Cadillac-Fleetwood/184272834372?hash=item2ae7844f44:g:bIcAAOSwvXReqHD3
