  #1
Old 09-08-2018, 03:19 PM
Steve Loftin Steve Loftin is offline
Groans: 1
Groaned at 7 Times in 7 Posts
Default Temporary seat repair
There's a tear in the front seat back of my '72 that I would like to cover for protection until I can (eventually) get it properly recovered. I've considered using something as simple as Flex Tape (clear or black):
https://www.flexsealproducts.com/pro...SAAEgLv9vD_BwE
Is there any reason I shouldn't use this product? Are there any other suggestions?
Proudly using my own name for 62 years.
The Following User Says Thank You to Steve Loftin For This Useful Post:
Chuck Kramer (09-29-2018)
  #2
Old 09-08-2018, 04:06 PM
Kurt Arends's Avatar
Groans: 7
Groaned at 1 Time in 1 Post
How are you planning on "repairing" it? You are probably going to have to send the entire upper vinyl cover to SMS to have another embossed properly. That said, it really doesn't matter what you use. Black duck tape will work just fine.
1996 S&S Masterpiece
1975 S&S Victoria 3-Way Landau
1975 Superior Cadillac 54" Ambulance(Ex Decatur Ambulance Service, Decatur, IL)
1974 M-M Cadillac Lifeliner Ambulance(Ex Minden City/County Safety Authority, Minden, NE)
The Following User Says Thank You to Kurt Arends For This Useful Post:
Steve Loftin (09-08-2018)
  #3
Old 09-08-2018, 09:18 PM
Michael Mykulak's Avatar
Michael Mykulak Michael Mykulak is offline
Default seat repair
I would go to an upholsterer and buy or ask for two scraps of black leather. Get on scrap and bond some foam to the finished side of the leather, slip it in behind the rip with the ruff un-scived side of the leather facing out and carefully glue in increments the torn flaps against the strata of the leather you have laid underneath the rip. Then find a piece of leather the exact same size as the rectangle portion you just bonded, with the same grain pattern and grain direction, to lay over the repair. It should not be visible at a glance any longer if you took your time and did not try to do it all in an hour. I am an upholster's younger brother and my brother always used
"S-18" All purpose cement in his business and I always keep some in stock for special projects because it really works well. The only drawback is if the can is not sealed after use air tight it will dry up. If you keep it to long the bristles on the applicator attached to the cap will actually dissolve and the metal baton may surprise you next time you open it to use. Both have happened to me.
The Following User Says Thank You to Michael Mykulak For This Useful Post:
  #4
Old 09-08-2018, 09:29 PM
John ED Renstrom's Avatar
John ED Renstrom John ED Renstrom is online now
Groaned at 3 Times in 3 Posts
believe it or not we have a man up here that can repair that forgot the screw driver on my back pocket problem. going to have to do that on this 72 up here also. but like you just not right now. if it was me doing it a curved needle and some string floss just do a little lock stitch and basket weave pattern across the hole the lock it in with the vinyl glue from locktight. I get mine at the ace hardware. did one on the wife's Monti Carlo that way it still holding. after 6 years. tape will just transfer sticky to your back side.
drop in for coffee anytime
  #5
Old 09-08-2018, 11:25 PM
Groans: 7
Check to see if there is a "Dr. Vinyl" franchisee in your area. They could fix that rip and have it virtually un-detectable. They did all of the upholstery repair work for the Omaha Auto Auction when I first moved down here. They do beautiful work!
A leather patch will not match your vinyl seat upholstery very well.
The Following 2 Users Say Thank You to Kurt Arends For This Useful Post:
Michael Mykulak (09-08-2018), Steve Loftin (09-10-2018)
  #6
Old 09-08-2018, 11:39 PM
Default auto detailers
I have seen a well auto detailers come to used car lots fix cracks in dash covers, respray carpets back to color, and repair tears in seats to where they are undetectable.
  #7
Old 09-10-2018, 07:03 AM
Website Member
I had a hole about that size in my front seat and it was repaired. Surprised the heck out of me how it could be done but he did it and then re-sprayed the seat.
  #8
Old 09-10-2018, 11:48 AM
Groans: 1
Quote:
What does "re-sprayed" mean (paint? dye?), and why--or when--should it be done?
  #9
Old 09-10-2018, 12:20 PM
Groaned at 9 Times in 9 Posts
The vinyl is cleaned, and then wiped down with a special liquid that opens the pores of the material, and then sprayed with vinyl dye. The dye is made by SEM Products. https://www.semproducts.com/ I have used the product for many years, and have dyed the dash black on my 1969 when I replaced it with a blue one. It is impossible to tell that it was dyed, since the product bonds with the original surface and becomes part of the surface, instead of lying on top of the surface like paint does. It is the standard of the automobile industry for over 50 years for renewing car interiors if they are faded, torn, or otherwise damaged. Finding someone that can properly do the repair and dye the seat will be the difficult part. I suggest that you ask at some of the larger used car dealerships for recommendations of who they use. Vinyl is repairable, cloth is only replaceable.
  #10
Old 09-13-2018, 09:36 AM
Website Member
Groaned at 0 Times in 0 Posts
There is a Dr. Vinyl in Tulsa:
Address: 10716 E 55th Pl C, Tulsa, OK 74146
Phone: (918) 627-3715
I may have to check that out myself. One of my corners is torn
1968 Cadillac MM Combination
The Following User Says Thank You to Blake Sherwin For This Useful Post:
Steve Loftin (09-13-2018)
Similar Threads
Mortuary cot repair Denny Shira Funeral Related Items 10 02-10-2017 07:43 PM
Cot repair/parts? Rich Koski General Discussion Forum 9 07-16-2013 12:31 PM
best rust repair ever John ED Renstrom Technical Discussion Forum 0 07-03-2013 11:16 PM
Rust Repair Kevin M. Lyons Sr. Technical Discussion Forum 10 03-31-2012 12:54 PM
