  #1
Old 05-08-2011, 03:45 PM
Dave Hopping's Avatar
Dave Hopping Dave Hopping is offline
Website Member
Groaned at 0 Times in 0 Posts
Default Electrical Aggravation
OK,the day before yesterday I went to start my '73 S&S (stock except for aftermarket oil press/water temp/ammeter gauges and switchable electric fuel pump by the tank) Turned the ignition to the accessory setting,turned on the electric fuel pump for about ten seconds,turned it off,turned the ignition to star,got a soft "clunk" as all the lights went out at once and wouldn't operate again.No sound at all when I tried the start position on the ignition,no headlights or interior lights,either.
Later that evening I opened the door and the interior lights came on nice and bright.Tried to start it again today.Everything was fine until I turned the key to start,then I got the same scenario as before.
Diagnosing any electrical problem,especially at a distance,is a little dicey,but does anyone have any suggestions as to which closets to start looking in for the electronic skeleton(s)? Thanks,guys.
  #2
Old 05-08-2011, 03:50 PM
Mike Burkhart - Deceased 1948 - 2016's Avatar
Mike Burkhart - Deceased 1948 - 2016 Mike Burkhart - Deceased 1948 - 2016 is offline
December 30, 1948 - October 21, 2016
Could be a bad connection on one of the battery cables at the battery.......
Check out my photo album.
The Following User Says Thank You to Mike Burkhart - Deceased 1948 - 2016 For This Useful Post:
Dave Hopping (05-08-2011)
  #3
Old 05-08-2011, 03:53 PM
Bill Leverett's Avatar
Bill Leverett Bill Leverett is offline
PCS Member/Super Site Supporter/Paramedic Supervisor
Groaned at 1 Time in 1 Post
Default Check the ground
I'm no electrical wizard but what I've learned from this board is no matter what the electrical issue, always start by checking for a good ground. Clean the battery terminals and connectors well. Also check the ground strap/cable where it attaches to the motor or chassis.
From there...well, I'll let the electrical pros speak to that.
Bill Leverett
1953 Pontiac/Barnette Combination
The Following User Says Thank You to Bill Leverett For This Useful Post:
  #4
Old 05-08-2011, 06:16 PM
Groaned at 9 Times in 9 Posts
The lights coming on and then a clunk along with darkness would leave me to believe that it is a bad positive connection at the battery. I suggest that you remove both battery terminal ends, and using a batter terminal wire brush, clean both the terminals and the battery posts. If it continues to give you problems, then loosen and then snug up the ground wire where it attach's to the engine block. If your car has the ground wire going to the frame, then I would relocate it to a bolt on the engine. If it still gives you problems after you do this, then it is high resistance in the positive wire that goes from the battery to the starter solenoid. Once again, some will chase their tail and do the checks in a random method, and stop once they get the car started, only to find that they didn't find the complete problem.
  #5
Old 05-08-2011, 09:51 PM
Michael Lee Michael Lee is offline
Website Member
Default same as my problem
I made it to the gas pumps went to restart after refilling and clunk It was on mine the after market battery clamps that the wire slides in and two bolts tighten down on the wire the clamp had power but the wire did not so I have replaced them with new wire with the machine ends like it came from the factory $45.00 at napa fix the problem on my 68
The Following User Says Thank You to Michael Lee For This Useful Post:
Dave Hopping (05-09-2011)
  #6
Old 05-08-2011, 10:50 PM
David Martin David Martin is offline
Website Member
As one who spent 20+ years in the Towing business I learned quickly that #1 Starters usually give an indication they're going before the actually do and #2 the quick roadside diagnosis was usually: If you've got lights and they go out when the key is turned it's a battery. Sometimes a Jump will work but a stone dead battery sometimes can be charged and won't take it anyhow.
The Following User Says Thank You to David Martin For This Useful Post:
  #7
Old 05-08-2011, 10:57 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
yes charge the battery. if the voltage is to low to start the chunk is the solenoid going in they the lights are out. go back in and check later the voltage comes up a bit and the lights work. usually a bad connection as described is not letting the battery charge back up or it just gone bad.
drop in for coffee anytime
  #8
Old 05-09-2011, 01:52 PM
Website Member
Default Sucess.....Maybe
Paul's mention of the positive terminal got me thinking,so I got the Mrs. (who got an "A" in high school auto shop-I didn't even take it) to watch the interior lights with the door open while I wiggled the positive battery cable.Sure enough the lights flickered.I took the terminal apart,sanded off the gunk and corrosion,put it back together,hooked it up and everything seems to be working fine.Started right up several times.
About a month ago,the top radiator hose let go and got coolant all over.I think maybe the positive terminal was so gunked up that the connection went bad.I'll bear in mind that the battery is not the only thing in the engine compartment that got wet,so Miss Thing won't be going out for a spin just yet.
Thanks again for all the ideas and direction .This isn't the first time y'all have made a big difference.
  #9
Old 05-09-2011, 07:27 PM
James Maguire James Maguire is offline
It's worth noting that if the cable CAN be wiggled, you have a problem. And sometimes even when the connection seems tight, you still have a problem. One trick we used to use way back when... tap a flat bladed screwdriver between the battery post and the cable clamp.
  #10
Old 05-09-2011, 10:52 PM
Quote:
The last thing that I would want to be doing is using a screwdriver in a way that it was never intended. There is only one way to safely check a battery terminal end, and that is to take it apart. If you use a screwdriver you run the risk of damaging the battery post, or causing a spark that can cause the battery to explode. Yes, the chances are remote, but if you happen to be that one in a 100 people that has a battery explode in your face, then the other 99 don't matter. This advise to use a screwdriver to test a connection is tantamount to putting a penny in the fuse box when the fuse blowes.
Similar Threads
Electrical overload! Steve Loftin Emergency lighting and Sirens 45 06-09-2014 05:14 PM
Electrical help needed. John Royark JR Technical Discussion Forum 4 12-07-2012 05:12 PM
Electrical Help in MO Mike Johnoff General Discussion Forum 4 10-20-2011 11:20 AM
New electrical problem Jean-Marc Dugas Technical Discussion Forum 2 10-23-2010 11:42 PM
Electrical troubles Jean-Marc Dugas Emergency lighting and Sirens 20 09-02-2010 02:32 AM
