  #1
Old 03-16-2018, 04:05 PM
Website Member
Default Bigger Shocks
Can I get bigger more heavy duty shocks for the Lifeliner? Currently the rear has air shocks which simply does not give me the support and lift I would like to get in the rear. Current shocks have pins both up and down mounting in to the mounts.
Thoughts?
  #2
Old 03-16-2018, 09:26 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
the only thing you can get that might be better is the coil over. but the air shocks if they are working should be better then them. before you do anything else do this put at least 40 psi in the rear tires. if the max is heaver then that put them up to max and run it around the block. all the suspension in the world can't compensate for a weak side wall tire. I fought that on the 72 Seville till I got the air up to were the manufacture sand to run the tires at.
drop in for coffee anytime
  #3
Old 03-16-2018, 09:39 PM
Groaned at 9 Times in 9 Posts
Put air bags between the differential and the frame. They aren't inexpensive, but they will give you a lot of lift.
  #4
Old 03-16-2018, 10:48 PM
Groaned at 0 Times in 0 Posts
Best thing would be go to a truck spring shop and have them rebuild both rear springs. They could even add another leaf to raise it up more. All the air shocks lift etc is just a bandade for age weakened springs.
Denny Shira (03-17-2018)
  #5
Old 03-17-2018, 03:20 AM
Website Member
I'm with Paul. Pair of 5" Firestones and enjoy.
I put a pait on my old Explorer, even though Nobody made a kit to do it. Called myself Nobody Industries for a few years too.
Just don't drive the vehicle until you get the tubing hooked up and at least 10 pounds of pressure on the system.
  #6
Old 03-17-2018, 10:35 AM
Been there done all that. The car wallowed like a pregnant heaffer. So put new springs under it. Still flopped like a fish out of water. So I put the coil overs under it now it handled like a wading bird, butt clear up in the air darting back and forth. So then I took the radial tires off and put bias ply back on. Better but still squirrelly. Then i was looking in the glove box and it lists tire size and air presser. It said 890 x 15. 25 psi front 40 psi rear. So i set the rear tire presser to what the manufacture stated and all my troubles went away. Most of the handling is from the rear. Most poor handling is from incorrect tire pressure. Set that first then if you still have trouble do something with the suspension. Your mileage may differ from mine but that is my experience.
Kurt Arends (03-17-2018)
  #7
Old 03-18-2018, 05:37 PM
Website Member
You read instructions?
That can cost you a corner notch on your man card.
The Following User Says Thank You to Walter Suiter For This Useful Post:
Clay Sellick (03-19-2018)
  #8
Old 03-18-2018, 10:21 PM
with the crowd run with we burnt that card way back. all we care about is got threw one more day
Similar Threads
Air Shocks for 72 Superior James Fischer Technical Discussion Forum 4 05-06-2012 03:43 PM
Help with caddy shocks Trent Weinman General Discussion Forum 2 01-23-2012 10:33 PM
shocks Russ Austin Technical Discussion Forum 3 12-11-2011 09:06 PM
rear shocks Josh Horton Technical Discussion Forum 3 09-22-2010 11:42 PM
