  #1
Old 06-04-2014, 03:25 PM
Groaned at 0 Times in 0 Posts
Default Pass Keys issues
Just a tip that may or may not work. Recently with my 96 S&S Cadillac I had flashing of "Passkey Fault" light while driving then we progressed to starting and shutting down after about 30 seconds and finally cranking but not starting at all. After doing some research one suggestion was disconnect battery for 24 hours. Did it and Passkey has not been heard from since.
  #2
Old 06-04-2014, 03:35 PM
James Fischer James Fischer is offline
Website Member
Default PassKey
I have had Passkey issues with my 95 Cadillac,and I have found once they begin they just kind of irritate you to no end......so with that I had the PassKey system by-passed...havent had one issue since....
My goal in life is to be the person my dog already thinks I am. ........
1970 Superior Cadillac 54" Super Rescuer
1972 Superior Cadillac Model 626
The Following User Says Thank You to James Fischer For This Useful Post:
Kyle Martin (06-04-2014)
  #3
Old 06-04-2014, 07:40 PM
Pat Post Pat Post is offline
Website Member
Groaned at 2 Times in 2 Posts
Here's a little tip on pass key. Found this out on my '94, take a q-tip and rubbing alcohol and clean the ignition cylinder. What's happening is the reader is getting dirty and losing contact with the key.
The Following 2 Users Say Thank You to Pat Post For This Useful Post:
Kyle Martin (06-04-2014), Peter Grave (06-04-2014)
  #4
Old 06-04-2014, 09:34 PM
Scott Crittenden Scott Crittenden is offline
EMT / PARAMEDIC
Groans: 1
Groaned at 1 Time in 1 Post
I've heard of people having trouble with a worn key, switching to the less used one can help.
[B][I]"The scrutiny was more than I bargained for"[/I][/B] Dr. John Jensen
The Following User Says Thank You to Scott Crittenden For This Useful Post:
Pat Post (06-04-2014)
  #5
Old 06-04-2014, 10:51 PM
Kevin M. Lyons Sr.'s Avatar
Kevin M. Lyons Sr. Kevin M. Lyons Sr. is offline
PCS Life Member / Platinum Super Site Supporter
rub the key with a dollar bill
The Following User Says Thank You to Kevin M. Lyons Sr. For This Useful Post:
  #6
Old 06-04-2014, 11:56 PM
Kyle Martin Kyle Martin is offline
Website Member
Default pass key
spray electrical contact cleaner in the tumbler (key) slot. can of air (like you clean your keyboard with) sprayed afterwards. works. used car lot remedy.
AMBULANCE JOCKEY
  #7
Old 06-05-2014, 12:02 AM
Jeremy Moberg Jeremy Moberg is offline
Junior Member
I've heard there is a kit you can install to bypass the passkey system. The impala ss forums is a good source of knowledge for that era B body cars. Follow the link if you want to check it out http://www.impalassforum.com/
The Following User Says Thank You to Jeremy Moberg For This Useful Post:
James Fischer (06-05-2014)
  #8
Old 06-05-2014, 12:09 PM
Rocky Pollard Rocky Pollard is offline
I have had this problem with a '96 Cad limo. Actually I was having several problems that at times would mask over the underlying issue. In the beginning the Antitheft Module was beginning to fail. It would shut the car down some days and other days it worked properly. Then the battery failed one morning just a couple hours before the car was to be used on a funeral, I sent it to a garage for a new battery to be installed. Then the pass key fault light would come on and off as the car was being driven. I sent it to an auto electric shop to have the system in their words "jumpered". They measured the resistance in the key and installed a resistor to "jump" the system.
Occasionally the car would just take a notion to not start, usually when I needed it the most! I then sent it to another garage and they verified that the electric shop had correctly measured the resistance and installed the proper resistor so the Pass Fault System was disabled. They then began a long investigation of the entire electrical system. They determined that the battery installer had installed a 700CCA battery which is 150CCA less than specs call for. (its 770 on a standard Cadillac and 850 on a Commercial Chassis).They replaced the battery with a 850CCA then installed a ByPass devise like the one mentioned above.
Lessons learned here: 1-Proper battery is a must. 2-See that the proper resistance is used in the "jumper" 3-investigate the Anti Theft Module 4-use competent repair shops.
I was taught to respect my elders.
It's just getting harder to find them.
The Following User Says Thank You to Rocky Pollard For This Useful Post:
Kyle Martin (06-07-2014)
  #9
Old 06-05-2014, 01:05 PM
Website Member
Talking
Quote:
What is this "dollar bill" you speak of?
  #10
Old 06-05-2014, 03:22 PM
Wayne Krakowski Wayne Krakowski is offline
Is this the same problem Richard Vyse was having with his,couldn't find his post but seems he went through the wringer till he got it corrected.
Similar Threads
Coach keys. Stephen Everhart General Discussion Forum 17 09-01-2013 11:54 AM
Keys....... Paul Steinberg Technical Discussion Forum 2 07-23-2012 08:05 AM
A passage of keys Tim Prieur General Discussion Forum 15 09-27-2010 10:46 PM
blast from the pass John ED Renstrom General Discussion Forum 5 12-15-2009 05:43 PM
