I have found a New Jersey source that states they an reproduce the sill plates in the Eureka. from what I have see they used a wide piece of aluminium with a etched pattern in it. then it was cut to fit what ever car they were working on for a number of years. all of them that I have seen are bad. the thin sheets did not hold up will. so testing the waters to see if there is any interest in getting some of this stock reproduced. what we would end up with is a long wide piece that you would use yours for the pattern to trim the ends and inside to.
