Just noticed today the bullet lights and red side lights are not working. I have power to the console, the side lights and beacon are functioning properly. Any help or leads are appreciated. Thank you!!
I would guess that if it is more then one or two lights, that the problem is a blown fuse, or possibly a defective switch. If you want to take a drive up to my home, I will find the problem and fix it for you, but check the fuse first. The auxiliary fuse panel is either on the outside of the firewall, on top of the inner fender pan, or inside, on the right hand side under the dash.
check the wire to the flasher. they flashed. the inside switch tripe the flasher.
that one is wired with a lot of independent wires and a few inline fuses. as I recall most of the power wires came off the siren relay. but here are the easy places to check first
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
