Hello Once Again,
Today I come Before you all seeking Tips and Insight on what the Correct method/way would be to Disconnect Various Hose's and Lines Through the Engine Compartment Area, without damaging anything or Part.
I'm working on Removing the Engine from my 1970 Superior Pontiac Hi-Top Ambulance, As I would Feel alot better if I had the Engine gone completely through (A Peace of Mind type of thing) and had anything worn or in need of Replacement done at this time rather than later down the road.
I guess you could consider it an Engine Refreshening/Tune-Up
But there are quite a Few Hose's and Lines Spanning Across the Engine that will need to be Removed or Moved Temporarly, then later Re-Installed.
Most of Which Trace back to the AC and Air Compressor's
I guess what I'm getting at is what would be the Correct way to Remove/Move those lines/Hoses without damaging anything Related to them.
I had made a Start to do this, and thought to myself that I should talk to someone with some Backround in this type of thing before I go Removing/Replacing Lines....And thats where I'm at now.
I would like to replace some of the lines if at all possible as they appear to be pretty Aged, others, I think, I may just clean up and Re-Install if possible
Thanks in Advance for any Help and Insight You Can Offer me
-Ryan
-Ryan
