GM used the same key blank groove configuration for both the ignition and trunk / glove box from 1935 to 1966. Starting in 1967, in an effort to combat auto theft, they change the groove configuration on both the ignition and the trunk to be separate grooving. To add to that, they also added a letter code to designate each of the key blanks. Below is an explanation of the years that each letter code designation correlates to.
The 1967 & 1968 GM keys continued to use the standard hex & pear shaped keys, even thought they changed the keyway configuration for each year.
1967 = A & B Keyways
1968 = C & D Keyways
Starting in 1969, GM changed the head of the key to a larger square, and a rounded top square for the door and trunk key. This was done because of
the introduction of the steering column ignition and lock. The new square & round top keys fit the following years.
1967 1971 1975 1979 1983 1984 1985 = A & B
1968 1972 1976 1980 1987 1988 1989 = C & D
1969 1973 1977 1981 GM Key = E & H
1970 1974 1978 1982 = J & K
First implemented in 1986 by General Motors, VATS keys were originally only for the Corvette. They were later used for the Cadillac and its future models. A VATS key, (VATS standing for Vehicle Anti Theft System,) is a key often referred to as a 'computer chip key.' These keys need to be programed by a locksmith or the GM dealer. If you loose one of these keys, it can get very expensive to have them replaced. In some cars, if you have 2 original keys, you can have additional keys programmed using these 2 keys and the special codes that allow it to be programmed using the cars computer system.
I found some key pictures on eBay so you can see the various keyways used for the various years, and how they differ. The keyways also changed on the backside of the key, so you couldn't put a "wrong" year key into the lock. This is just an simplified overview and there are other "factors" that come into play, such as the key cuts themselves being proprietary to each year. Unless you want to become a locksmith, it is more information than you need to know.
