Solid body dead paint. 78,400 Clear title in my name. just a little bit of rust in the left front door and in the skirt area. Non is rust thru . Uncut dash nice interior. Mechanical issues addressed. A/c repaired and serviced with R-12 no conversion done, rear brake shoes and wheel cylinders, muffler and resonator , valve cover gaskets , tuneup ,carb rebuilt , exhaust leak repaired on rt side. Tires are 99% tread but old no problem around town but I would replace them before a long distance trips. Seat has spit in it but have a roll of materail to go with it. Windshield had a crack in in upper rt I had it drilled and filled to stop the crack. You cannot see it from the outside but can from the inside. New center link. Upgraded the battery cables to one gauge. One piece of trim and the MM emblems are off and with it ,glue died and need to be reattached. Solid coach needing paint as the biggest issue. One of those body styles you do not see a lot of. Lots off pics in the below link . Any questions give me a call @ 760-247-3693 Thanks
Link For More Pics http://postimg.org/my.php?gallery=j6qotao4
