but the evidence of bondo does not have to mean rust repair. as it's a pro car one will only get to guess from pictures. who ever grafted the 59 fins on did a decent job. from them so it may have be repaired correctly. the mud one doesn't know if it's a 16th of a inch or 3 inches deep from a pictures. the only think one knows is it doesn't have a 1/8 inch of primer on it.
but to redo all that work would be harder then fixing a little rust. you can only work the panel so many times before it's to thin to work again.
