  #111
Old 03-14-2018, 06:33 PM
Website Member
Groaned at 0 Times in 0 Posts
Yes, there is a Shell in Owasso with 0 ethanol 91 octane. I cant get 93 though
1968 Cadillac MM Combination
The Following User Says Thank You to Blake Sherwin For This Useful Post:
Philip Scanio (03-14-2018)
  #112
Old 03-15-2018, 12:59 PM
Website Member
Its a good possibility that a previous owner installed one of the $12 universal ignition switches. Someone else suggested I use a cheap one to test and linked this:
https://www.ebay.com/itm/1946-1968-C...UAAOSw0UdXqecP
This looks EXACTLY like what I have now, which may be a big part of the issue if this is cheap switch cant handle what going through it. Mine even has that tiny little lockbox looking key with it.
  #113
Old 03-15-2018, 09:25 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
that switch is fully capable of handling the load . but you can't have it as yours has a GM key. or at least you showed us what you said was your switch key and it was a GM key.
drop in for coffee anytime
  #114
Old 03-16-2018, 09:17 AM
Website Member
The key I showed was my door key. Ignition key is different. This is my ignition key
  #115
Old 03-16-2018, 10:39 AM
Peter Grave Peter Grave is online now
Son you have the CHEAP CRAP switch. I know its the cheapie cause it has the double sided key. The better ones had a heavier single sided key. There is way to beat the too heavy load on the switch. You may have to do some rewiring and use a relay.
  #116
Old 03-16-2018, 10:46 AM
Since it's all ready aftermarket just get a good one and replace it. Some one as all ready done the cut and splice. I'm betting one of there crimped on conductors is lose. Solder all them and the problem goes away. That door key that was not cut for your doors was most likely not even for that car.
  #117
Old 03-16-2018, 11:33 AM
Website Member
Thanks, I know the OEM part number is 1116701 D-1440A
Offhand does anyone know of any particular aftermarket switch that will swap cleanly without having to make further modifications. I would like to find something that I can install without risk of screwing it up more.
No problem if no one knows offhand. I will do some research, but if you happen to know of one it would be appreciated. Only thing I've seen so far is the $465 NOS Delco switch
  #118
Old 03-16-2018, 11:35 AM
Website Member
Quote:
I see what your saying. I may just have to pull it out, take some pics and compare them on the internet.
  #119
Old 03-16-2018, 06:17 PM
Right now it would be foolish to even try to go back to the original switch. The best bet for a good aftermarket is find one made in the USA with a brand name. Replacing should be easy except for the tight quaters you have to work in. I am with Ed if you can solder (rosen core not acid core) the terminal end where the wire goes into the end that will ensure a good connection to the terminal. If you can buy or borrow an old Weller 250 watt soldering gun thats what to use . If you can't find one I'll loan you one of mine.
  #120
Old 03-16-2018, 09:20 PM
most defiantly your in to a look see before you can decide what direction to go. there is no way to say what someone else did with out a eye ball on it. but here is a good aftermarket switch you can have it as soon as it put the original one back on
