Took the Lifeliner in to get the 28 siren mounted/installed and decided to have the seal on the rear end replaced since it was leaking just a bit. Decided to change the rear seal on the tranny too and now decided to change the drive shaft bearing that is in the middle just to be on the safe side. My radiator was spewing a bit so the radiator is coming out and will be boiled, once again to be safe replacing the lower hose to match the new upper hose. Going to have a little bit of paint work done and hope to have enough left over to detail/paint the engine compartment then off to the shop for the new headliner.
