Rick Davis
Two things- First, do the Roadmaster based hearses (Superior, S&S, etc.) use standard front doors?
I recently purchased a 96 Superior that had the drivers front door window smashed out. My mechanic tried to put in a used standard Roadmaster door glass, but could not make it go up and down correctly. He called in a glass shop that brought out a new window which had the same problem. The glass "expert" gave up and left.
The problem is that as the window goes up, it curves to the inside of the door rather than following the track into the frame. By forcing the window outward it will go up and appears to fit the frame as it should.
Any ideas??
Any ideas??
