the lights on this 67 are crossing over each other so as long as it's in we took the time to adjust them. for those of you that have not used this equipment here it a short story. the adjusters need to be set for the floor and each other and checked offer, set flat on the tabs on the light. then as you look down into the mirrors you will see a split image. I didn't catch both of them in this picture but the lower one would have the same image as the upper one has. you then adjust the horizontal so that both mirrors show a straight black line across them. then the vertical is set with the level on the top. you move one adjuster you move both the horizontal and the vertical. as the headlight sit on 3 points and you only adjust 2. so recheck to other each time you move one.
