I would like to change my heater valve out on my Criterion to see if that will produce heat. Anyone got one cheap?
TKS
:thumbsup:
TKS
:thumbsup:
The less expensive method to checking the valve is to see if the water is hot on one side of the valve, and cold on the other side. If you want to go to the effort to change the valve, then just replace it with a mechanical valve from NAPA or Carquest. You can still find the original vacuum controlled valves on ebay, but they are usually very expensive. The replacement mechanical valves at Carquest are under $20 and are very easy to install. My 1969 Miller Meteor ambulance has a cable controlled mechanical valve for regulating the hot water to the rear heater. It appears to be originally installed when the vehicle was new.
If I were to install a valve and turn the water on manually, that would mean I would have heat on all the way right? I will check this weekend when I get the Criterion out to play with.
no listen to what I have said. the valve is "open" that is "open" all the time. the only time it will close is when you set the control inside the car for max air. you should have water flowing all the time except on max air. if you think it is not working take it off. run the heater hose right into the heater. but if you have a hot hose going in and a hot hose coming, out the valve is open leave it alone. set the inside control to 85. the fan should now come on and you should have hot air coming out of the floor. if not, it's not the water valve's fault. look else were for a different problem. the mistake that is made is to have the control on say 70 deg. with sun light shinning in. the inside tem may be 70 deg at the temp sensing unit passengers side dash. the controller then shuts down the fan as it at temp on the inside. if it's warmer then 70 at the sensor then it closes the heater off and adds more outside air to try to bring it back down. it does that threw the dash vents. if it still won't come down it will kick the compressor on to bring it down to temp. keeping the heater damper off. so say you got hot water flowing threw the heater and the fan will run at all speeds. but you still have nothing but cold air at the floor or other vents. it's a vacuum problem. if you have good vacuum going into the control unit. you then check the door operation. one may be jammed or the servo not working. but 9 times out of 10 it's one of the splices that have broken. as caddy was big at putting them right behind the brake pedal some big footed guy may have kicked them apart. does the vacuum pull off for the park brake work? same main line. most people run out and buy the new 50 to 75 dollar heater control valve because it does not shut off the water flow. then when the new valve does not shut off the water flow either they blame the inside controller as being bad. both are working as they should. it is just the vacuum hose that is split and sucking air. the first thing is you have to understand is the system and how it is engineered to work. it may be built different then you think. I have learned the hard way the water valve is. I have also learned that the Oldsmobile system and the caddy system work differently to achieve the same results. you must get a book
