what this?
not begin the expert on these cars, you get a new one in and you get to learn about it. was this filler panel standard on a crown or something some one has added? it's cut for the car and has all the over cuts and things that make it look superior. but I have never seen one before. it slid in under the sill plate and was screwed there. a perfect trap for mud and water to slid in under it. jamming up the last two set of rollers
we got the rollers free up and all the latches to work so now we can make it a ambulance. found all the screws to put them back together under the floor with a magnet. used a little lick tight on them this time. then sealed up the rear end as all the sealer had dried out.
funny how zipping things over the buffer will make them look so much better.
Plate
My 65 has same filler plate. It is a Crown also. This last pic is of a friends 70 , I have only seen it a few other times. A cover flips down in the back and has a extra set of rollers in it.
