Peter Grave - Deceased - 1938 - 2022
Lengthy decription by seller go read his ad. Following is part of it. A beautiful Cadillac. Front disc breaks, electronic ignition. Starts right up, shifts as it should. small chip in the windshield way down low center. Interior overhead lights and sconce lights not working, (needs new interior door light switches.) Drivers interior door handle needs repair. (Door still works though from both inside and outside...) The passenger door seems haunted. Once in awhile it doesn't want to unlock, otherwise doors lock and unlock with the key or manually. Gas gauge is intermittent. Floor pans are good, some rust in the bottoms of the doors but you have to crawl underneath to see it. New exhaust. Great tires with a spare included. Interior looks good with temporary door coverings. I have the original panels...New carpet installed through out, three bench seats with belts installed as well. (seats 7) All horns work! As with any used car there will be a few issues. Drivers side window comes off track and gets stuck sometimes. Passenger side wing window doesn't work.” https://www.ebay.com/itm/1967-Cadil...ash=item466ddb9a51:g:UTQAAOSwPK5Z5QCn&vxp=mtr
