Keith Snyder
You have to have some imagination to see this one for what it really is; a diamond in the rough! This "survivor" is one of only either 50 eight passenger sedans of one of just 119 1956 Chrysler Crown Imperial limousines built. from the pictures presented, it's hard to determine which it is - a sedan or a limousine. In any event, these are scarce and collectable. It’s located in San Jose, California and is listed for sale at $3,500. Too bad the seller didn't post some better pictures and some of the interior as well. Hope it finds a good home.
http://sfbay.craigslist.org/sby/cto/5942952855.html
We are told this is one of 74 1956 Chrysler Imerial ghia limousine available to president Eisenhower for his entourage. It's not in good shape but has most parts and some resto work was started. The suspension was rebuilt and brakes converted to dual master cylinder. The wheel cylinders were all honed and new seals. The shoes were in good shape so the drums were deglazed and shoes refitted, there is a good chance it will have to be redone or at least some of it. The engine is a basket case and has one very large hole in one piston but a good candidate for rebuild. Crank is good as well as block heads rods etc. I don't recall the measurements we took on the cylinders but I some how think we were only looking for a piston along with bearings rings and chain. The water pump leaked when we fired it up on seven cylinders, but yes it ran (like crap) but run it did. Some extra parts go with the car, some interior trim parts and latches, door handles and the eagle for the front. The headlight rings and one side louvre are missing along with one of the long side trim pieces I was going to make one from two. Only some interior trim and couple of exterior trim parts missing. We even have the wheel covers, though I like the artillery wheels with a trim ring and derby. Trans is the push button three speed I believe, though we didn't run it long enough to find out for sure ☎ (408) 510-9238
