  #1
Old 09-22-2015, 12:14 PM
Rich Cosner Rich Cosner is offline
Website Member
Groaned at 0 Times in 0 Posts
Default Transmission Fluid
It's that time again... Newbie Question Time!
Will this be ok for my 58?
The transmission started slipping a bit and I am "praying" that it's just low on fluid. I haven't checked it yet. I recall seeing something like "Use only Cadillac something or other" fluid on one of the caps, not sure which one.
AmazonAmazon
  #2
Old 09-22-2015, 01:12 PM
Website Member
Now I remember why I got confused. The cap says both Power Steering and Transmission fluid. Will that work for both? And is it possible to overfill this like it is for oil? I am guessing no, but with my past record of me and putting too much oil in various engines, I figure the only thing it could hurt to ask is my pride. I'm not a mechanic, can you tell?
  #3
Old 09-22-2015, 01:25 PM
Depends on how low it is. You MUST check it hot running after idle for at least 15 min DO NOT DRIVE IT LOW you will burn up the trans. If oil is not visible on stick after wiping stick off and reinserting it will take at least three quarts. Note engine must be running when checking it ain't like motor oil. I recommend Dextron II for older hydros. If you can find a parts store with a stock of old fluid then regular Dextron is the way to go. Call me with any other questions I am not far away 610-216-0045.
Rich Cosner (09-22-2015)
  #4
Old 09-22-2015, 01:35 PM
Website Member
Quote:
Ok, I had to drive it to work the last 2 days as my other car is in the shop. I'll have to at least get it home. It's only about a 15 minute drive. I'll take it super easy. Judging by a preliminary internet search, I will be lucky to find the Dexron II. And so I am clear, that's also the power steering fluid in the same reservoir?
  #5
Old 09-22-2015, 02:20 PM
Website Member
Ok, I just checked it. Ran for 15 minutes, wiped and checked. Looks dry as a bone. A few little drops appear on the back of the dipstick. Nothing significant. I'm a little leary about moving it at all now.
Do you know of anywhere in the Allentown/Bethlehem vicinity that I could pick up some Dexron or Dexron II. I could have my wife pick me up from work and head to an auto store after work. I assume all the normal places are going to only have the new Dexron IV. I read it's supposed to be backwards compatible with GM's?
For sure, I'de rather have the recommended type, but leaving the car in the work parking lot while I wait for an ebay purchase to arrive (only place I found online to have Dexron II) is kind of debatable.
The Following User Says Thank You to Rich Cosner For This Useful Post:
Richard Vyse (09-22-2015)
  #6
Old 09-22-2015, 04:58 PM
DON'T DRIVE IT LOW put the new stuff in probably will take three or four quarts just do it its not going to hurt anything in the short term. And no the power steering and transmission are connected in anyway. Take note on left front of engine ( right front as you face coach) you will see a round cap that is power steering fill. You have ny phone number if you need more info.
  #7
Old 09-22-2015, 07:59 PM
James Fischer James Fischer is offline
Website Member
Default Dexron
Some additional help from an earlier thread regarding Dexron:
http://www.professionalcarsociety.or...ad.php?t=18009
My goal in life is to be the person my dog already thinks I am. ........
1970 Superior Cadillac 54" Super Rescuer
1972 Superior Cadillac Model 626
  #8
Old 09-22-2015, 08:02 PM
Groaned at 9 Times in 9 Posts
Also pick up a can of Seafoam, and install it along with the transmission fluid. Even if it is over full by a pint, it won't hurt anything, and after a few weeks of driving, the Seafoam will be absorbed into space somewhere. Never could figure out where it went, but it is back to the full level after a while of driving. It will smooth out the shift pattern, and condition your seals. This is the only thing that my transmission repair shops suggests that you try before they pull the transmission. It worked well for me, and should do the same thing for you.
James Fischer (09-22-2015), Peter Grave (09-22-2015)
  #9
Old 09-22-2015, 10:46 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
that is the sea foam transmission tun.
drop in for coffee anytime
  #10
Old 09-23-2015, 01:29 PM
John Royark JR John Royark JR is offline
Groaned at 1 Time in 1 Post
As for the transmission power steering fluid question, Im not sure if anyone really explained that. If so, I missed it. Back then, they used trans fluid for the power steering reservoir, instead of power steering fluid. It is two totally separate systems. Hope this clears that up for you. Others have pretty much explained everything else, and when checking the trans fluid, do not check it after driving it, it will give you a false reading. Just start it and let it idle to get up to operating temp--10-15 minutes or so. And like others said, do not drive it if the fluid is low, or instead of paying $10 for fluid, you will be looking at well over a grand in repairs when you burn it up.
Current owner of:
1949 S&S Cadillac Knickerbocker combo
1985 Superior Cadillac Sovereign FWD hearse
1985 Eureka Pontiac Chieftain hearse
1995 Superior Chevrolet Chancellor hearse
See all my pro cars past and present in my photo album
Similar Threads
Transmission Fluid for 70 James Fischer Technical Discussion Forum 6 09-01-2015 08:22 PM
Transmission cooler Kevin Lynch Technical Discussion Forum 8 07-26-2014 10:42 PM
Transmission question Linda Evans Technical Discussion Forum 10 01-06-2014 09:35 AM
Transmission rebuild Joseph G Unrein General Discussion Forum 2 08-21-2010 01:03 AM
Copyright © 2009 - 2018 Friends of the Professional Car Society
