Cruising home from the local car show last night when I applied the hi-beams on the Pontiac. Lost all headlights, which made for an interesting last mile on the dark road. Parking and turn still work.
New headlight switch was installed some time ago.
Following the test procedure, I do not have any power on the red wire to the back of the headlight switch. Manual says fusible link.
I cannot find any visible direct red wire to the battery as indicated on the schematic, so I am thinking it must be on a wire wrap in the front engine harness?
Any thoughts as to where the fusible link is?
Thanks.
Thanks.
