New electrical problem
Something new that I have noticed a few weeks back is that after 10ish minutes, the flashing pattern of the bullet lights start to slow down untimely they stop flashing.:bonk:
It takes quite a while after I turn them off to work properly again.
My guess is that the old relay gets tired and quits once it gets warm.
Ideas, suggestions?
more likely the flasher then the relay. but don't forget the switch. feel around for which one is hot. but don't burn yourself. they can get really hot.
Check your ground, often times a poor ground will cause the flasher to get hot and track and the lights will quit working and just stay on or they will go dim and just go off.
