1957 master cylinder fill
I know this is a stupid question, but I got a new m/c and I cant see where you add the fluid. Anyone know, I know this is going to be a nightmare bleeding this set up:argue:
Is there a filler somewhere higher up on the firewall that gets plumbed to the master? '54 and '55 at least had a filler on drivers side firewall and line running down to the master under the floor.
Here's a pic of what the filler might look like, I'll take a look at my Superior later today.
on my '54 and '55s that filler is bolted to the firewall and goes down to the master that is mounted to the frame under the floor. I'll take a look at the '57 in a couple of hours and report back. This is one in a '54 circled in blue
Yes, heres mine I found it laying on its side in engine compartment. I didnt know what it was. So I dont need to fill the master? :argueing:
Drivers side firewall, but filler is on passenger side of booster
Optional. So we ve determined that that is the m/c fill up tube I jusy need to connect it somewhere. Im redoing the brakes. New m/c, wheel cylinders, brake lines
