Now that the rear heater hoses have been replaced, it is time to move to the next small project.
I was thinking about replacing the fuel line that links the fuel tank to the fuel pump. Currently, the fuel line is connected to the fuel tank via a rubber hose and weaves its way to the fuel pump where it is connected, again with a rubber hose.
The fuel line itself is not currently secured to anything. It just rests on top of the cross members and has worn out rubber hose sleeves where it rubs against something.
Ant tips or tricks that you can offer me before I launch into this next project? Anything else I should consider while doing this?
As always, thanks in advance for your comments and suggestions.
