Rick Davis
I just purchased a 1994 S & S Buick Victoria. It's missing the rubber portion of the body side trim on the front passenger and on the driver side rear fender. Does anyone know if a replacement is available?
rick, try your buick dealer or aftermarket for the trim. i bought a roll for a roadmaster and the trim guy replaced it all for a nominal sum. trim supply house or online. buick used to have it and you bought it by the foot.I just purchased a 1994 S & S Buick Victoria. It's missing the rubber portion of the body side trim on the front passenger and on the driver side rear fender. Does anyone know if a replacement is available?
Do you recall where you bought the trim? I've had no luck at all finding a source yet.
This is a plain black strip, 1 3/8" wide, flat with rounded edges mounted to the stainless trim.
I do have a sample of some watercraft trim that looks similar coming. I guess worse case scenario is replacing all the trim so it matches.
