Notices
Old 10-03-2018, 11:09 PM
Default maybe
I have got to thinking and trust me this always cost me money. I have stated a number of time if things go south, go the the last thing you fixed before the dip. will in the case of this 72 Seville it was the water pump. the car had sat for sometime with what must have been straight water in the block. the pump that was on it had had rust about half way up. so much that it bend the impeller when we started it. the only thing separation the water pump and the timing chain is a steel plate. it was pitted but look solid. I'm going out to were the car is tomorrow and pull that water pump. my bet is the plate has a hole on it now. as water is pouring into crank case when you fill the radiator. just can't see that happening in any other location. it should look like the last picture.
Old 10-04-2018, 12:11 AM
Bill Marcy's Avatar
Bill Marcy Bill Marcy is offline
Groans: 1
God Bless you Ed, you have patience and know-how.
Co-Chair PCS 2016 Gettysburg Meet
Editor of The Criterion
Past PCS VP
Past Northeast Chapter President
Past BoD Member
Co-Chair PCS 1999 Lancaster Meet
And I have to say that I enjoyed every minute of it!
Old 10-04-2018, 12:41 AM
Kurt Arends's Avatar
Kurt Arends Kurt Arends is offline
Groans: 7
That's an awefully clean looking 455 that you bought Ed!
1996 S&S Masterpiece
Old 10-04-2018, 11:29 AM
But as usual I get into trouble when things inside are off. If that 65 dollar timing cover is the problem I have a expensive boat securing device here.
Old 10-04-2018, 10:28 PM
picked up the car today and towed it home. we got it striped down this far and took a picture. I can see a small hole threw but don't know if it alone will account for the rate of water flowing into the oil pan. I get a puller tomorrow and we can get it off and look at the backside.
Old 10-13-2018, 10:36 PM
got everything back together again. we ended up putting in a new timing chain as the we were down that far and the other was warn enough to change it. got things sealed back up and the car even started after a prime. I haven't set anything don't have a clue were the timing is right now but let it run for about a hr and it looks like it will hold water were it should be. we took it out for a run just to stir things up a bit and when we got back things were still as they should be. if it's holding presser tomorrow we will call it cured and move on.
set the points and timing were they should be and get the carb overhauled. valve cover gaskets that hold oil and drive it some. the heater works no control but it needs to be hot now anyway. we'll mess with stuff later right now we have a Pontiac to finish. you can here it run here https://www.dropshots.com/jer57747/d...10-13/16:42:28
