in between stuff on the 58 I trying to bring up the rigs I have around here that are mine. the former owner of the 72 made the attempt to put a radio in the dash. they did have the correct radio. but much to his dismay when they went to put it in they discovered that a GM delete in 72 was a little more then just a blank spot in the dash. the supports for the radio, the mounts for the speakers the wiring necessary to make it work were just not there. then cutting the hole in the aluminum backer by hand was not as neat as stamping it. I did thank my lucky stars that they did not start the project with chopping a hole in the fender for the antenna. now that I have the experience and the template out we can look for a better substitute then the piece of veneer I used. I have just enough left to do it one more time. but no way to re due the lettering. most will never notice that but once changed you can not get it all back the same. close
