Old 05-16-2019, 10:39 PM
David Henry's Avatar
David Henry David Henry is offline
Default S&S Rear tunnel lights
Somewhere on this site, I read that the rear trim rings on an S&S Ambulance were actually a headlight ring off maybe a Ford? Anyone have any specific info on what they actually are?
Current owned:
1974 Sayers and Scovill Professional Ambulance
Previously owned:
1973 Miller Meteor Lifeliner Ambulance
Future ownership:
1971-1973 Wayne Sentinel Suburban Ambulance
Old 05-17-2019, 04:55 AM
They look very similar to a 1967 Pontiac Bonneville, but you should take one off and look for a casting number on the inside. With that, I might be able to give you more information.
The Following User Says Thank You to Paul Steinberg For This Useful Post:
David Henry (05-17-2019)
Old 05-17-2019, 09:52 AM
Keith Snyder Keith Snyder is offline
Groans: 5
Groaned at 2 Times in 2 Posts
I was given to understand that those were 1971 Cadillac headlamp bezels.
Old 05-17-2019, 10:36 AM
Steve Loftin Steve Loftin is offline
Groans: 1
Groaned at 7 Times in 7 Posts
He's asking about the trim rings (around the bulb itself), not the mounting bezels.
Proudly using my own name for 62 years.
Old 05-17-2019, 12:01 PM
The ring around the bulb could be any one of 4 different configurations that were used to hold the sealed beam headlights into the headlamp assembly. There are two different cut outs for the tabs that are casted into the bulb so you can only use the correct bulb (either high beam or high / low beam bulb), and then each bulbs location had the tabs in different locations to properly locate the bulb in its proper location on the car. Now, if they are using the red bulb with the screw tabs on the rear, that particular sealed beam will fit into any of the 4 housings. It is a difficult thing to visualize with only words, but once you see the 4 different housings, it readily becomes apparent how the system works in the headlamp configuration. I would need to see a bulb mounted in the body, without the chrome trim ring to be able to determine which was used. Once again, look for a part number stamping on any of the parts that you have, and check to see if they are the same on the left and the right (passenger) side.
Steve Loftin (05-17-2019)
Old 05-17-2019, 10:33 PM
John ED Renstrom John ED Renstrom is online now
I would go with the 71 caddy bezels. But the give away would be do they have the notches for the screwdriver to pass threw. If they used a car bezel they would be there.
The Following 2 Users Say Thank You to John ED Renstrom For This Useful Post:
David Henry (05-18-2019), James Fischer (05-18-2019)
Old 05-18-2019, 09:14 PM
Ed,
They have the holes that look like they are for adjusting a headlight, one on top and one on the side. As always, appreciate your input.
Current owned:
Previously owned:
Future ownership:
The Following User Says Thank You to David Henry For This Useful Post:
John ED Renstrom (05-19-2019)
Old 05-23-2019, 06:48 AM
Paul
Here is a photo of the back of the trim bezel on the rear tunnel lights.
Current owned:
Previously owned:
Future ownership:
Old 05-23-2019, 08:42 AM
Peter Grave Peter Grave is offline
Guide IS GM and thats a GM part number. I don't have a 71 Cadillac parts book if someone does easy to check number.
  #10
Old 05-23-2019, 08:52 AM
The ring is something that they made up themselves, so send them out and have them re-plated. Same with the bezels, yours are in good enough shape to have them plated also. The bezel is a 1971 inner (high beam) bezel. That bezel has long ago been discontinued, so even if you found a NOS one, it would cost more than having that one plated. It is only money when you go down the rabbit hole restoring a car.
MM pod tunnel lights tag, 70's Channing Spencer eBay Listings Discussion Forum 4 04-20-2016 05:12 PM
Front tunnel lights, including the tunnel! Kevin Lynch For Sale To The Public At Large 4 01-18-2016 09:52 PM
Differences in tunnel lights... Richard Vyse General Discussion Forum 2 10-18-2009 09:08 PM
