Go Back   Friends of the Professional Car Society - Official Website of the Professional Car Society, Inc. > Professional Car Discussion > Emergency lighting and Sirens
Emergency lighting and Sirens For discussion of emergency lighting and sirens as they are associated with Professional Cars. Posting in this forum is limited to PCS Members and / or Site Supporters. We encourage all website users to become members of the Professional Car Society and / or become Site Supporter.
Old 05-07-2015, 07:08 PM
Bill Marcy's Avatar
Bill Marcy Bill Marcy is offline
Groans: 1
Default Mounting Question
I am making a little progress with my 68 Superior ambulance, but I have a slight problem. The previous owner had given me a Federal Model 78B which he bought from John Dorgan. It is restored and gorgeous. My problem is that when we tried to mount it, the holes in the roof do not line up with the holes in the base of the siren/light. In addition, it seems to lack a gasket that goes between it and the roof. What can I do? See pictures below. Thanks for any help.
Co-Chair PCS 2016 Gettysburg Meet
Editor of The Criterion
Past PCS VP
Past Northeast Chapter President
Past BoD Member
Co-Chair PCS 1999 Lancaster Meet
And I have to say that I enjoyed every minute of it!
Old 05-07-2015, 08:45 PM
There are no mounting gaskets, but you can purchase rubber washers and put them between the mount and the roof. The wires that are showing in that picture are for the light and the brake. You need a minimum of a 6 gauge stranded machine tool class K wire for the siren itself. This is an extremely fine stranded (266 strands in the bundle)(class K) wire, that is both easy to work with, and will give you the best electrical conductivity. The least that I would consider is 133 strand class H 6 gauge wire. This should be available from local electrical supply houses in larger cities where there is manufacturing. The other alternative is to go to www.delcity.net and order 25 feet of 6 gauge red or black battery cable wire.
The Following User Says Thank You to Paul Steinberg For This Useful Post:
Bill Marcy (05-07-2015)
Old 05-07-2015, 09:19 PM
Steve Loftin Steve Loftin is offline
Groans: 1
Groaned at 7 Times in 7 Posts
To my knowledge, no Federal motor siren on a 1959-70 Superior used a Federal mounting bracket except for a Q2*. Because of the angle of the roof over the cab, none of the sirens would sit level if the Federal (contour) bracket was used. Therefore - as discussed here often - Superior used their own mounting brackets during these model years. The 1959 through 1964 series used a fore/aft sliding adjustment, while the later version (seen on cars into 1972** until the inventory was used up) had a through bolt for adjustment. The adjustment was necessary because the roof angle was slightly different between the lowtops and hightops; that way, the same bracket could be used for both. Many examples of Superiors with Superior brackets can be seen on this site.
Your car either had a Q2 on the roof from the factory or another Federal (four hole mount) siren installed there later.
*I'm guessing the reason the Federal brackets were used on the Q's is that the Superior brackets weren't stable enough (footprint too small) to handle the torque and weight of the larger siren.
**As seen here:
http://www.professionalcarsociety.or...&postcount=151
Proudly using my own name for 62 years.
The Following 2 Users Say Thank You to Steve Loftin For This Useful Post:
Bill Marcy (05-07-2015), Tim Prieur (05-08-2015)
Old 05-07-2015, 09:34 PM
Groans: 1
The same adjustable Superior mounting brackets were used for factory installed CP25 speakers and Mars 888 lights between 1965-70, as seen here:
http://www.professionalcarsociety.or...&postcount=110
The Following User Says Thank You to Steve Loftin For This Useful Post:
Old 05-07-2015, 11:54 PM
The Superior Mount... Don't know if the two small holes in the front of the mount were added by Superior, or by someone else after it left the factory. This mount is not for sale.
The Following 4 Users Say Thank You to Paul Steinberg For This Useful Post:
Bill Marcy (05-08-2015), Dave Lisiecki (05-20-2015), Jerry Jacobson (05-08-2015), Steve Loftin (05-08-2015)
Q2B mounting question..... James Fischer Emergency lighting and Sirens 4 03-07-2013 09:33 PM
Grille mounting a Q JR Rotramel Emergency lighting and Sirens 3 02-08-2013 01:20 PM
Mounting weather stripping Richard Vyse Technical Discussion Forum 16 02-04-2013 11:56 AM
Help with mounting a Q2 James Fischer Emergency lighting and Sirens 13 07-19-2012 12:27 PM
Siren mounting Paul Steinberg General Discussion Forum 11 08-28-2010 11:07 PM
